Author Topic: brake piston installation, bearings grease?  (Read 855 times)
Offline Shik
« on: July 28, 2012, 04:26:53 AM »
Hi,
Can I use bearings grease for car brakes for my cb550?
Jesper
Re: brake piston installation, bearings grease?
« Reply #1 on: July 28, 2012, 04:35:56 AM »
Some people just put some brake fluid on the actual piston part to give it a little lube when it is pushed back in.Any grease used on the brakes should be of high temp variety. Here is a starter thread to get you going.   http://forums.sohc4.net/index.php?topic=104349.0
« Last Edit: July 28, 2012, 04:39:50 AM by ekpent »
