Author Topic: Candy Gold K1 750, Update 10/28/12 Completed for now  (Read 16442 times)
Offline Johnie
Re: Candy Gold K1 750, VIDEO!!! Update 8/05/12 WE GOT POWER!!!!
« Reply #25 on: August 05, 2012, 07:35:44 PM »
Maybe his OEM ignition went bad and that is all he could come up with. In any event, I would get it back to OEM by putting together some bullet connectors or solder and a new switch. Or see what you can find on eBay as far as an OEM switch. Ideally, you maybe can get lucky and find someone parting out a K1 and get the entire male / female connection with switch and key. They are out there...
EDIT: as I look at the pics again, I see an OEM switch under the tank. Are you saying you do not have the key or did he boogy up the wiring???
« Last Edit: August 05, 2012, 07:38:25 PM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Tews19
  • I am no
« Reply #26 on: August 05, 2012, 07:40:04 PM »
I have 3 of them. Not sure how the wiring is underneath, but am I able to use the by cutting the wires long enough to soder together then usse the male female caps that I have?
1970 Honda CB750 survivor.
« Reply #27 on: August 05, 2012, 07:48:33 PM »
Yes, you can solder and/or use bullet connections. Just no wire nuts, ok?!
Offline Johnie
« Reply #28 on: August 06, 2012, 05:49:41 AM »
You should be good to follow the wiring color patterns and she will be good to fire...
Oshkosh, WI  USA
Offline Tews19
  • I am no
« Reply #29 on: August 12, 2012, 09:50:11 AM »
I order a new set of rubbers for her. Battlax 45s. Removed the side sprocket cover. I was nervous opening her up. Thinking there may have been a thrown chain and the case is cracked. Well got it off and not one crack! Minus old dirt she look really good. Hopefully more evidence of the miles being accurate. More wishful thinking so far.
Also got her titled in my name.
« Last Edit: August 12, 2012, 09:58:45 AM by Tews19 »
Offline dhall57
Re: Candy Gold K1 750, Update 8/11/12
« Reply #30 on: August 12, 2012, 10:28:57 AM »
Great Tews no cracked or damaged case ;D That made your day I'm sure ;)
« Last Edit: August 12, 2012, 11:58:34 AM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #31 on: August 12, 2012, 10:45:21 AM »
Looks like time to order a chain and sprockets too Tew
Offline Tews19
  • I am no
« Reply #32 on: August 12, 2012, 10:52:05 AM »
I was going to ask what chain you all recOmmend for a 750?  I am diggIng my Regina brand for my 550.. Thinking I want to go good with the chain to keep the theme going.
Offline Tews19
  • I am no
« Reply #34 on: August 12, 2012, 03:18:35 PM »
Yep, used my bench grinder for my 550 chain.
« Reply #35 on: August 12, 2012, 03:25:23 PM »
Good, you know the drill. I use a hand grinder and put the chain in a vise.
Offline Johnie
« Reply #36 on: August 12, 2012, 05:03:22 PM »
I have the EK X-ring on all my bikes. Very satisfied with the performance.
Oshkosh, WI  USA
« Reply #37 on: August 12, 2012, 05:19:57 PM »
And you can get it in gold!
http://www.motorcycle-superstore.com/1/4/61/5608/ITEM/EK-530ZVX2-X-Ring-Chain.aspx
Offline Tews19
  • I am no
« Reply #38 on: August 12, 2012, 06:02:43 PM »
Man that's expensive! 1/4 of what I paid for her.
« Reply #39 on: August 12, 2012, 06:25:23 PM »
Johnie's loaded, he can afford it!
Offline Tews19
  • I am no
« Reply #40 on: August 12, 2012, 06:45:05 PM »
Sorry didnt see the edit part. I have a key now. He cut the plastic connection plugs off to attempt to get the bike started. I'm really aiming to make some serious progress the next few days.
Offline Johnie
« Reply #41 on: August 13, 2012, 05:36:57 AM »
Just looked at my EK530 X-ring chain receipt I got from my dealer this year. List was $117 and I paid $94. That other site looks like a rip-off. I imagine you are changing the sprockets too. Remember to add a little blue Lock-tite to the 2 small bolts that hold the front sprocket on. There has been issues with those backing out.
Oshkosh, WI  USA
Offline Tews19
  • I am no
« Reply #42 on: August 13, 2012, 05:50:14 AM »
Johnie, can you PM me a contact number to your source? I used locktite on the 550 will do the same on this one. Tonight I plan to pick up some flitz to help remove the rust from the frame and new spark plugs. Carbs have been sent off...
One thing I am debating, do i remove the swing arm and put on one i have that looks brand new. One currently has lots of rust. Tires will be off tonight as well.
Offline sallen
« Reply #43 on: August 24, 2012, 09:00:47 AM »
Tews--You're bike is coming along nicely. Have you had any luck finding any HM300's? I just recently bought a set off CL in Utah. Nice used ones, little bluing on header pipes;$275. No rust out or dents. I will have to buy baffles though. They are out there, just have to be patience or lucky..  I bought a Candy Gold K1 from Johnie here on SOHC just within the last month.  Steve
1975 Honda CB550K1
1950 Norton Dominator Model 7
1930 Harley Davidson 45DL
« Reply #44 on: August 24, 2012, 07:02:25 PM »
Johnie sold one of his bikes? And didn't tell us??
Guess he had to pay for that shop?
Offline sallen
« Reply #45 on: August 24, 2012, 09:12:12 PM »
Stev-o---it wasn't one of his herd..was one he picked up to flip...I couldn't afford one of his nice ones..but, it was nice enough for me. Steve
1975 Honda CB550K1
Offline Tews19
  • I am no
« Reply #46 on: August 25, 2012, 10:08:16 AM »
Made progress today. Removed the rims, forks, swim arm. Cleaned up the rims  very pleased how they came out  Dropped off the rims at a NEW bike shop and got great service. Minus the fact motorcycle superstore didnt send my tubes????!! WTF is it with my bikes and tires. I contacted motorcycle superstore an they apologized for not sending them. Here she is as of now.
Need some advice now. The fork tubes are good but do have some rust and very minor pitting. On my other K1 I have like brand new tubes from Forking by Franks. Should I swap out or clean up the tubes as best I can an leave this K1 original?
I also took a good look at the rear rim an noticed road rash. The bike had to have been dumped at one time. Upon inspection and I can't believe I missed this.
I am pretty sure the miles may be correct as the engine vin looks to be hand stamped. Might be why the cases look to be new. I'm thinking a chain was thrown originally and an engine was redone due to it. Any insight for this would be helpful as well!
There is so much dirt on this bike. I'm leaning towards taking her down to the frame and getting her powder coated. More insight would be appreciated whether I should or not?
« Last Edit: August 25, 2012, 10:13:55 AM by Tews19 »
Re: Candy Gold K1 750, Update 8/25/12 pics! Lots of ?'s
« Reply #47 on: August 25, 2012, 11:33:44 AM »
Yes, engine VIN appears to be stamped, probably broken case.
Id use the better tubes.
On the 6th pic above, is that dirt on the rear wheel area and muffler? If that's rust, needs paint or PC.
Offline Tews19
  • I am no
« Reply #48 on: August 25, 2012, 11:54:54 AM »
It's all dirt. I sprayed it with a hose and the top came clean but man the underneath is still full of dirt.
« Reply #49 on: August 25, 2012, 12:08:44 PM »
note those chewed up rear sprocket studs/nuts...that bike definately threw a chain....on cleaning, wd40 works great as a light degreaser, I would just clean stuff up as best you can, disassemble stuff if you can't get your fingers in there, I don't see any reason to powdercoat that frame yet, but yeah, you gotta get it clean
