Author Topic: how to route inline fuel filter on cb550  (Read 4367 times)
Offline xsmooth69x
« on: August 01, 2012, 03:25:25 PM »
the carb for cylinder 1 and 2 has a ridiculously short tube from the petcock to the little hole where the fuel line feeds through the carb bracket to the carbs......
i imagine the fuel line is gravity fed so how do you route the fuel lines with an inline filter.......
1975 CB550 (FINISHED?!?!?)
jontc
Re: how to route inline fuel filter on cb550
« Reply #1 on: August 01, 2012, 06:09:28 PM »
Where did you buy the in line filters?And your fuel lines?Was it in town or on line?
Offline Fritz
« Reply #2 on: August 01, 2012, 06:20:33 PM »
I bought a tiny filter at a local bike shop. I think that routing of the fuel line is not that crucial. Keep it short and avoid high spots that could trap air.
After a while I threw out the filter because I felt that there was not enough space for it and it started to bend. Fearing that it might break I just did not feel save. The petcock filter should be sufficient if the tank is fairly clean...
1976 CB550F
Offline xsmooth69x
« Reply #3 on: August 01, 2012, 06:48:55 PM »
i got fuel lines from my local motorcycle shop. im sure i already got shiat for them being crappy but i think they will do. ya my petcock filter screen thing is mint and i was just going to put the inline fuel filters in for good measures but my tank is clean so idk. unless there is a certain small fuel filter everyone uses that i dont know about....
Offline brooze72
« Reply #4 on: August 01, 2012, 06:54:47 PM »
This is correct, haven't seen anyway to do that because of those short runs, standard filters with loops cause problems, ask me how I know... then just use your mint petcock filter.
1972 CB500K1 - restored rider
1981 CB650C - new project
jontc
« Reply #5 on: August 01, 2012, 07:01:53 PM »
On my 350 cl the filters are clear triangle looking things,is that what you have?And on the lines I will try out a few shops that are close.I have been watching your build ....u riding yet with a few set backs or getting close
Offline xsmooth69x
« Reply #6 on: August 01, 2012, 07:43:09 PM »
been so busy i have been neglecting my build thread......
but the bike is done other than my other throttle cable question post.
i will work on my build thread tonight
going to the dmv tomorrow to get the new frame titled and thats it!!!
then i can learn how to ride a motorcycle!!  ;D
bollingball
« Reply #7 on: August 01, 2012, 09:20:12 PM »
I just don't see a reason for more filters. If two makes you feel better then three would be much better right? About the smallest one you could find would be for a lawn mower or other small engine maybe check your local mower repair shop. I think you are adding more places for possible leaks and air traps. IMHO.
Ken
Offline xsmooth69x
« Reply #8 on: August 02, 2012, 12:52:26 AM »
ya i ditched the inline fuel filter stuff. petcock filter is fine  ;D
