Author Topic: Still too new to know...75 750  (Read 1876 times)
Offline Dannodarko
« on: July 29, 2012, 09:05:13 AM »
Is there a way to change the needle height without taking the carbs completely off the bike every time? My bike is still running way too rich, and today I'm going to start messing with the jet sizes. When I bought the bike it had pod filters, 4-1 exhaust. Now I have 4-2 and stock airbox with a k&n filter. I attempted at syncing the carbs and it just didn't work, my idle speed kept increasing while I was performing the adjustments on the carbs to the point where I had the idle screw backed completely out and it was idling at like 2 grand...and words of advice??? The idle jet size is a #42 I believe and I'm not sure about main jet size... Thanks all in advance for putting up with my newb carb questions. - Dan
Offline lucky
Re: Still too new to know...75 750
« Reply #1 on: July 29, 2012, 09:25:07 AM »
You have to remove the carbs to change the needle position.
One easy way is to remove the throttle return spring ,then lay them face down on a towel so they do not slide around, and just take the screws out of the backing plate. Lift off the entire backing plate carefully and then you can easily remove the slides. Be careful to not move the carbs while the backing plate is off.
You need to find out and write down which jets you actually have.
Syncing carbs is the VERY last step.
To get it to not run too rich you need to know WHICH carbs you have. look for the numbers on the carbs. That way you will know the correct needle position. #3 or #4.
Then you will know the stock needle position.
The #42 idle jet will probably work well with Pods.
If you are running the stock air box and filter use the #40 idle jet.
BTW...Syncing the carbs is to get all 4 slides to open at the same time while making a very slight height adjustment to compensate for the fact there are slight differences in the carbs and pressures and vacuums.
When you make that sync adjustment you are only moving the slide up and down .007 more or less. Look at .007 thousandths on a pair of calipers.
Can you please let me know which number of carbs you have.
Are you even sure you have 1975 carbs???
« Last Edit: July 29, 2012, 09:29:05 AM by lucky »
« Reply #2 on: July 29, 2012, 09:33:49 AM »
On carburators with 4-1 cable you can get slides out and change needle position with carbs still in.
Offline Dannodarko
« Reply #3 on: July 29, 2012, 11:05:54 AM »
Ok so I took the carbs out here's what I have. The carb numbers are 657B AMH, the pilot jet size is #40 and the main jet size is #115...
Offline Dannodarko
« Reply #4 on: July 29, 2012, 11:50:22 AM »
And here's what it looks like when I removed the throttle valve to check the needle height, very different looking than what's in the Clymer Manual.
« Reply #5 on: July 29, 2012, 12:17:48 PM »
Nice picture.
See those two cross head screws?  Take those out to get to the slide needles.
Stock settings can be found here:
http://www.motorcycleproject.com/motorcycle/text/specs.html
Hint: JN is the slide needle clip position counting grooves from the top of the needle.
I would expect stock settings would be a fairly close match for your bike in it's current configuration.
I wouldn't rely on the Clymer near as much as I would rely on the Honda shop manual.
Also, be aware the that adjustments are throttle position sensitive.
Offline lucky
« Reply #6 on: July 29, 2012, 01:00:28 PM »
Only with the great 1969-1970 carbs.
Offline lucky
« Reply #7 on: July 29, 2012, 01:02:18 PM »
The Clymer's manual covers many years of carbs from the 69's upwards. Chapter 3 and chapter 6 is all the carb info and photos.
Offline lucky
« Reply #8 on: July 29, 2012, 01:03:55 PM »
Use a #2 screw driver in those screws in that slide.
You do not want to strip them!!!
Offline Dannodarko
« Reply #9 on: July 29, 2012, 01:15:00 PM »
Hahaha I just tried to get them out, didn't wanna budge so they are soaking right now and I'll try it with the #2. Thanks again everyone!
