Hello all - SOHC 4 Newbie here.
I am overhauling a 1971 500/4 K0 in the UK. Its a USA import. Low miles <2000 but has been standing inside for years.
I am baffled by some issues with this bike as follows and wonder if anyone here can make sense of this:
1. Starts absolutely first dab of the starter or even by HAND on the kickstarter!!
2. Makes irrritating amount of whitey/grey smoke most of the time.
3. Compression tester shows less than 50psi on all 4 cylinders.
4. Exhaust smells kind of sulphurous/ steamy and continues to smoke a little after engine stopped. Noticed water dripping from exhaust drain hole.
The engine has just had new standard rings fitted!!! There was no damage or signs of wear to the bores.
Am I right in thinking valves issue here? Although I saw no problem when the head was off and all is working smooth and quiet. (Only thing I did find was a thick and hard to scrape off tan coloured residue on the valve heads).
Any ideas what is causing the smoke?? Is this a common issue? The exhaust smell is just not right.
