Author Topic: motorcycle test in ohio  (Read 1267 times)
Offline spatam
« on: August 01, 2012, 03:17:49 PM »
i am looking to go take my licence test here soon cuz i only have the permit. i sure i can pass it my concern is the cone weave other than that i think i will be ok. does anyone know if i can go to the test place to practice or the distance between cones so i can setup my own coarse.
Offline DJ_AX
Re: motorcycle test in ohio
« Reply #1 on: August 01, 2012, 03:39:15 PM »
I practiced for it in an empty lot... no cones just picked spots and lines to swerve and dodge.
All of the parameters of the test we're well defined for Michigan...but... I just guesstimated when I practiced.
Worked for me.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: August 01, 2012, 08:04:21 PM »
If you have a menards or lowes nearby they sell cones, the small ones are a couple bucks.
Offline TrueSpin
  • Not Really An
  • 1978 750F3
« Reply #4 on: August 02, 2012, 05:28:30 AM »
Pretty sure you can still just take the MSF and that certificate plus your permit is good for your endorsement/license.
That's what I did.
Offline mjstone
  • I'm definitly not a
« Reply #5 on: August 02, 2012, 06:03:05 AM »
That's what I did.
+1 on the MFS course.  That's the way it works in Michigan.  You pass the MFS and show your certificate to the SOS and they waive the skills test.  Best $25.00 I've ever spent.  Show it to your insurance agent and you will probably get a break on your insurance as well.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
Offline Xnavylfr
« Reply #6 on: August 02, 2012, 07:54:00 AM »
Here in NC the riding test course is on the MC test study book. You could possibly contact a DMV and them what is the distance between cones for the MC ride test.
A good way to practice , find empty parking lot and just set out 2 cones/cups about twice the length of your bike apart, start out about twice the length of your bike in-line with the first cone and ride as SLOW as possible around first cone then between them and make a U-turn and come back the other direction,  EASY. then start moving the cones/cups closer together this will become much harder to do. If you keep the RPMs up a little, the mass of your engine crankshaft spinning acts like a gyro to help stabilize the bike, you will need to slip your clutch to do this.
I think the cones in NC are about 12' apart.
Xnavylfr(CHUCK)
« Reply #7 on: August 02, 2012, 07:58:50 AM »
