Author Topic: Name that tank!.... Mystery Solved!  (Read 2415 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« on: August 01, 2012, 06:04:23 PM »
I've got a tank here that I can't identify. My experience is limited to mid to late 70's SOHC CB750's and I don't recognize this tank. The grey tank is a 74' CB750 tank, while the red tank has an identical cap and latch as the 750 tank, it is markedly different. The red tank is a little narrower at the front and rear, the red tank is also a little shorter in length, and the red tank has the petcock bung mounted at the rear of the tank with what appears to be two additional hose connections at the rear of the tank that point to the rear (a crossover tube possibly?). The underside of the tanks are also very different. So the question to the experts is:
Does anybody have any idea what this tank came from?  ???
One of the SOHC smaller sibs (450, 500, 550)?
« Last Edit: August 04, 2012, 06:25:08 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Dimitri13
  • 1974 CB550K
Re: Name that tank!
« Reply #1 on: August 01, 2012, 06:15:18 PM »
I can tell you it doesn't look like a 500/550 tank.
Offline kmb69
Re: Name that tank!
« Reply #2 on: August 01, 2012, 06:41:34 PM »
CB450 K3+
Re: Name that tank!
« Reply #3 on: August 01, 2012, 07:03:24 PM »
CB450 K3+
Cool, that gets me pointed in the right direction. Can't see where I'll have any use for it, will likely reappear in a for sale thread.
TAMTF...
Wilbur
Projects:
Re: Name that tank!
« Reply #4 on: August 01, 2012, 11:25:30 PM »
 They look good on CB 750's.. Mad Mel ran one..
Offline Brantley
  • Drano
Re: Name that tank!
« Reply #5 on: August 02, 2012, 12:32:13 AM »
I'd name it Charles.
Seriously, without provisions for trim I'd say CL350.
Re: Name that tank!
« Reply #6 on: August 02, 2012, 03:54:10 AM »
TAMTF...
Wilbur
Projects:
Re: Name that tank!
« Reply #7 on: August 02, 2012, 07:17:36 AM »
Per the parts fiches I'm thinking this might be a 1970 SL350 tank.
Nope, scratch that...
« Last Edit: August 02, 2012, 07:20:28 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline bluesmoke69
Re: Name that tank!
« Reply #8 on: August 02, 2012, 04:57:06 PM »
Red tank look just like my 1972 CL 450 tank and other looks just like my 1973 CB450 tank. Could be CL350 and CB350 also. Hope this helps.
Offline brooze72
Re: Name that tank!
« Reply #9 on: August 02, 2012, 05:01:00 PM »
How about Sherman :)
1972 CB500K1 - restored rider
1981 CB650C - new project
Re: Name that tank!
« Reply #10 on: August 02, 2012, 06:15:36 PM »
The grey tank is from a 74' CB750K for sure, I've been scouring other online forums (for picts) and parts fiches based on the suggestions here. It does appear to be in the 350 family, just trying to pin down the year. Doesn't help that the emblem recesses have been bondoed over. May strip the paint to help pinpoint the emblem recesses. Thanks for the input!
TAMTF...
Wilbur
Projects:
Offline Brantley
  • Drano
Re: Name that tank!
« Reply #11 on: August 02, 2012, 10:52:50 PM »
Sounds too tank-ish... Um, now that I've looked again, don't CL350's have the fill cap off to the side? I don't have a lot of experience with any 450 but don't remember crossover tubes on the ones I have seen. Where is the petcock mount?
Re: Name that tank!
« Reply #12 on: August 03, 2012, 02:40:15 AM »
CB450 K3+
Correct. I bought a really nice one in original candy ruby red (or close enough to) years ago thinking it was a 750 tank but when I realised that it wasn't, I ebayed it and sold it to a guy in Canada. Cheers, Terry. ;D
Re: Name that tank!
« Reply #13 on: August 03, 2012, 04:10:53 AM »
The petcock mounts at the right rear just in front of the crossover tube connection. Hard to see, but you might be able to just make it out in the 3rd picture.
TAMTF...
Wilbur
Projects:
Offline MickeyX
Re: Name that tank!
« Reply #14 on: August 04, 2012, 03:22:10 PM »
I'm voting for CB350. The 68/69 and maybe 70 version has a screw on cap whereas the later versions have the pop button. Also, the CB version, the tank covers over where the rubber hold down is, where the CL is shorter and leaves it very open. The CL seat rides up over that part more than the CB does. Thus the slight difference.  ;D
« Last Edit: August 04, 2012, 03:28:45 PM by MickeyX »
Offline kmb69
Re: Name that tank!
« Reply #15 on: August 04, 2012, 05:51:26 PM »
It is a CB450, K3 or newer (flip top cap) with emblem tabs filled in.
Re: Name that tank!
« Reply #16 on: August 04, 2012, 06:23:21 PM »
That certainly looks like it! The parts fiches were throwing me off since all the ones I could find for the CB450K3 (71') indicate the chrome trim covering the seam along the outer edge similar to the picture of the CB350 above. Thanks, mystery solved!  8)
TAMTF...
Wilbur
Projects:
