Well I took my spare f2 engine apart last weekend to start rebuilding as my "Endurance Racer Project" engine, all the grotty engine components are currently soaking in a big tub of diesel fuel I and took the cases and cylinders over to get chemically stripped. The guy there recommended bead blasting as he said that the "Hot tanking" they do isn't all that sucessfull in removing all the paint and corrosion.
They also do powdercoating there, but he recommended against it, he said that as powdercoat is an excellent insulator it'll keep the heat in (not good) so he'd definately recommend against heads and cylinders, and to a lesser degree, crankcases. Hmmnnn. so what do i do now? Paint comes off when it comes into contact with fuel additives, powdercoat isn't recommended as it keeps the heat in, what do I do?
Tony, the guy who runs the business, is a biker too, and suggested that as my bike is really only going to be a weekend "toy" anyway, to just leave the cases bare? He did his beautiful Kawasaki Z1 900 7 years ago and left the cases bare, and they still look good, so that'll do me. I'll polish the outer covers but the top and bottom cover, cylinder block and head will be "au natural". It'll sure make assembly and fitting back into the frame a snap too.
I saw this in a British bike mag, and all the owner did to combat road salt etc was to spray the whole thing with WD40 once in a while, but as this bike won't be seeing any of those sorts of conditions, it should work fine without it. Cheers, Terry.
