Author Topic: Too much head!!  (Read 1410 times)
bollingball
Too much head!!
« on: August 03, 2012, 11:11:23 AM »
That got your attention. I was doing my 3K tuneup in prep for installing HondaMans Ign box. New points,condensers, and all the other stuff that goes along with it. I was using my aux. fuel tank that I hang off the tracks of my garage door. The tank is about 8 feet up and had about 1 gallon of gas. A few hours laterI found my oil to the top of the tank. Gas in the oil tank. I am thinking there was to much head pressure and over riding the float valve. What say you. I have no problem with the oem tank hooked up. I will change the oil and filter. Has anyone else ran into this?
Ken
« Last Edit: August 04, 2012, 04:15:41 AM by bollingball »
Offline NewOldSchool
  • Apprentice
Re: To much head!!
« Reply #1 on: August 03, 2012, 11:14:03 AM »
Sounds like the pressure from the tank pushed past the floats/ fuel stops, flooded the cylinders and leaked? past the rings filling the engine with fuel....
I'm confused as this sounds crazy impossible to me????
Not putting miles on your bike is like not having sex with your Girl Friend so she'll be more desirable to her next Boy Friend.
Offline LesterPiglet
  • 1977 CB550F2
Re: To much head!!
« Reply #2 on: August 03, 2012, 11:16:32 AM »
Sounds plausible to me. There must be quite some pressure from a gallon of fuel 8 feet in the air all pushing down through that tiny tube.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
Re: To much head!!
« Reply #3 on: August 03, 2012, 11:21:09 AM »
Better add a second oil change to that 3k tune ;)
Re: To much head!!
« Reply #4 on: August 03, 2012, 11:40:39 AM »
Remember how easy it was to push in those tiny spring pins on the float valves?
Note the the I.D. of the hose, and realize that the column of fuel inside that hose has weight.  The volume of fuel from the float valve to the top level of the liquid will push on that spring pin.
(btw, you need and extra o in "to".  )  Seems topical, IYKWIM AITYD.  ;D
Offline aperry
Re: To much head!!
« Reply #5 on: August 03, 2012, 12:00:56 PM »
Did you have gas all over the floor?  I'm not familiar with your carbs, but one mine I think this lead to a lot of gas exiting through the overflow tubes.
Aaron
CB750K3 with F1 frame/swingarm
  • Apprentice
Re: To much head!!
« Reply #6 on: August 03, 2012, 12:18:31 PM »
Aaron
Thats what I thought was so weird?! I would think the gas would be all over the floor.
Re: To much head!!
« Reply #7 on: August 03, 2012, 12:19:20 PM »
Yep, did this on my 350F.    but it came out my overflow tubes.
I had hung my aux tank up off my garage door runners.
now, my aux tank sits on a rolling too chest next to my bike, just in front of my bars with the shortest fuel line I could work with.
bummer if you had already covered the oil change in your tune up.  :-\
bollingball
Re: To much head!!
« Reply #8 on: August 03, 2012, 12:29:34 PM »
Aaron
No gas on the floor. When I started it up to dial in my adjustments I shut it off and out of habit I check the oil and it was at the top of the tank :o Then I took a whiff. I looked up at my tank and saw it was half empty. Just wanted to bring it to attention to others to look out for.
 TT that makes perfect sense.
 Greggo Yes I will make sure I flush it out. Thanks for your input.
 I'm not that good at math. But I was thinking 5 gallons about 6" above the carbs versus 1 gallon 6 to 8 ft. above ? the same or more?
Here is a pic of the setup.
Ken
« Last Edit: August 03, 2012, 12:31:44 PM by bollingball »
bollingball
Re: To much head!!
« Reply #9 on: August 03, 2012, 12:47:28 PM »
Now I don't know why fuel did not come out the overflow tubes they are clear. ??? These are PD 42b carbs on a 78 750K. Floats are just at 14.5mm Fuel level is about 3mm below the bowl gasket. I am still working on this shooting for 4mm. This does seem odd. Any ideas?
Ken
Offline aperry
Re: To much head!!
« Reply #10 on: August 03, 2012, 01:15:07 PM »
Aaron
Ken
I am not sure the weight of the gas column matters all that much.  Most of the weight of that 1 gallon is supported by your garage door anyway.  It's the pressure buildup that really makes a difference.  The pressure is proportional to the height only.  It has nothing to do with the diameter of the column or the amount of gas in the container at the top (except if it adds more height).  In this case, 8 feet would indeed put a lot of pressure on your carbs.
If you've ever seen an 8-foot aquarium then you've probably notice how very thick that glass is.  This doesn't have anything to do with the volume of water or width of tank.  It's all about the height.
PS:  I am still very puzzled as to why nothing escaped the overflow tubes.  I mean, I would expect it to still be leaking when you entered the garage.  You're certain no PO blocked those things up?  I see it mentioned on the forum from time to time (seems like a terrible thing to do).
« Last Edit: August 03, 2012, 01:16:51 PM by aperry »
Offline Lostboy Steve
Re: To much head!!
« Reply #11 on: August 03, 2012, 01:37:41 PM »
Clearly i am in the wrong forum :)
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline CrankyOldGuy
  • Wish I was a
Re: To much head!!
« Reply #12 on: August 03, 2012, 04:48:53 PM »
hmmm ...  34 feet of water is approximately one atmosphere (14.7 psi).  If gasoline has a specific gravity of 0.75 then a head of 45 feet of gasoline would be approximately one atmosphere (14.7 psi).  Therefore 8 feet of head of gasoline would result in a pressure of approximately 2.5 psi (360 lbs./sq.ft.) give or take.
Note: no calculator was used just the old brain ... therefore the accuracy may be limited  ::).
Harry O.
« Last Edit: August 03, 2012, 04:51:26 PM by CrankyOldGuy »
750 K1 Original Owner
Offline CycleRanger
  • No comment about being an
Re: To much head!!
« Reply #13 on: August 03, 2012, 05:57:00 PM »
Yeah, try to keep the baby bottle the same height as the fuel tank to maintain similar hydrostatic pressure. :)
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: To much head!!
« Reply #14 on: August 03, 2012, 09:24:00 PM »
 ;D Me too, I never thought you can get too much.
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Re: To much head!!
« Reply #15 on: August 04, 2012, 02:00:05 AM »
To much head!!
Yep, no such thing.... 8)
Re: To much head!!
« Reply #16 on: August 04, 2012, 03:03:29 AM »
mr guillotin had tee shirts made?now thats revolutionary!
« Last Edit: August 04, 2012, 03:05:02 AM by dave500 »
