Author Topic: How to fix broken float post?  (Read 23898 times)
Offline NewOldSchool
  • Apprentice
Re: How to fix broken float post?
« Reply #25 on: August 08, 2012, 05:30:46 PM »
"I've read mixed reports but most people say the new gas with ethanol breaks down the JB Weld in pretty short order. "
Could be and thats good to know.  I find gas stations that don't have ethanol.  Both for the bike and the snow mobile.  There are lots of gas stations in Ontario that don't have ethanol.
Patched a pinhole in my tank with JB weld two years and 16,000 miles ago. No leak, and I live in CA where all  our gas is 5.7% ethanol.
Not putting miles on your bike is like not having sex with your Girl Friend so she'll be more desirable to her next Boy Friend.
Offline RatBikeRandy
  • Yes I Can
« Reply #26 on: August 08, 2012, 06:42:04 PM »
I drilled a tiny hole in post and body then cut very short length of paperclip.  Using the "new" paperclip post strengthener I JB Welded every thing back together.  Still holding after 5 years.
« Reply #27 on: August 15, 2012, 10:26:13 PM »
I'm jealous! Ours is 10% minimum.
« Reply #28 on: August 15, 2012, 10:58:06 PM »
California has a state mandate to blend ethanol with all the gas sold in the state.  If the pumps are labeled, not all are, they say up to 10% may be blended.  When I asked the station manager just how much ethanol was in the fuel, he didn't know, and wouldn't find out.  Three different stations behaved this way.  Basically, you buy whatever they offer, whatever it is.  Customer satisfaction has absolutely no meaning to the gas distribution industry.  Instead consumers are treated like addicts seeking a desparate fix.  (Which isn't too far from the truth.)  The drug can be "cut" with whatever, and however the dealer sees fit.  The consumer generally has no concept of quality product.
« Reply #29 on: August 15, 2012, 11:25:17 PM »
The non-political, ethanol-proof repair has already been mentioned:
http://forums.sohc4.net/index.php?topic=111096.0
Offline 2wheels
« Reply #30 on: August 16, 2012, 04:41:02 AM »
"They used plenty of it. I picked off gobs of loose JB Weld."
So you picked it off?  Was it soft and falling apart?  Just wondering.
Also I don't see any sand paper marks on the post.  The glue will not stick well to parts that have not been sanded or roughed up somehow.
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
Offline 72_350_FOUR
« Reply #31 on: August 16, 2012, 06:30:54 AM »
Dont even mess with it, just send it Jim, he fixed mine and it's perfect.
1972 Honda CB350F
Offline lucky
« Reply #32 on: August 16, 2012, 07:29:03 AM »
« Reply #33 on: August 16, 2012, 10:18:05 AM »
Met Jim at his home/shop this past month. That micro laser welder is the real #$%*!! His build is pretty badass too  ;) Not to mention he's a helluva nice guy.
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #34 on: August 16, 2012, 06:22:21 PM »
What carb body do you need? I've got lots!!! If I have what you need, it's yours no problem. Just PM me.
And what's with the stupid can't use brass in carbs crap. There's no end to the misinformation. Seems like the insides of my carbs have brass parts. I better tell Honda to knock it off. ::)
Offline Hush
« Reply #35 on: August 23, 2012, 03:49:14 AM »
What about hairline cracks in the actual bowl themselves?
Anyone got a fix for that, can I just rough up the whole base and spread JB over it, will that hold?
Offline mjstone
  • I'm definitly not a
« Reply #36 on: August 23, 2012, 04:20:45 PM »
Should work just fine, Hush.
MJ
1972 CB500Four (Honda)
1973 CB500Four (Oliver)
