Author Topic: Wider rim up front than in rear? thoughts?  (Read 2959 times)
Offline wiskey
« on: August 07, 2012, 09:48:04 AM »
So i am very close to buying a hayabusa front end and swapping it to my 1977 cb750. I have comstars powder coated black currently and have thought about just dropping in the entire front end off the busa, wheel and all. the wheels currently are a 18x 2.15 on the rear and 19 x 1.85 up front.
I know the front wheel is a 17x3.50 on the busa. and takes a 120/70/17 tire, the rear tire on my bike currently is a 120/90/18
My question would be what would be the potential disadvantages of running a wider rim up front. I have checked and some tire company's make a 120/90/17 tire and i'm not sure if that would be any benefit or not.
Another solution would be to swap the rear rim with something wider, however at this time i am not sure I want to get into swapping swingarms, I would put another rear on if someone knows a suzuki rear wheel that would "bolt on" that is narrower than the 17x6.00 from the hayabusa. I understand some other front ends may or may not bolt up easier but this one is a great deal from a friend if I decide to do it.
Offline xnewmanx
Re: Wider rim up front than in rear? thoughts?
« Reply #1 on: August 07, 2012, 10:05:02 AM »
It's not that hard to just make an axle and a brake adapter to run your stock wheels...
How much is he asking for the front end?  I installed a gsxr front end on my bike with my stock wheel for about 200 dollars total.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: August 07, 2012, 10:08:45 AM »
I've no idea about the rim width but won't dropping the wheel diameter 2" make a big difference to handling?
Offline wiskey
« Reply #3 on: August 07, 2012, 10:12:43 AM »
brake spacers I get, but what would I need to do to make an axle? I mean would I have to turn down the busa axle?
$300 is his price.
Offline xnewmanx
« Reply #4 on: August 07, 2012, 10:16:21 AM »
No.  I'll draw a quick diagram of how I made mine and it works perfectly.
brb
Offline wiskey
« Reply #5 on: August 07, 2012, 10:19:14 AM »
brb
Thanks! Really appreciate it.
Offline xnewmanx
« Reply #6 on: August 07, 2012, 10:22:26 AM »
OK.  This sketch is WAY more ghetto than how it works out in real life but you can get the idea... i hope
you can buy most of the stuff from mcmaster.com
Offline wiskey
« Reply #7 on: August 07, 2012, 10:35:10 AM »
thanks. So does that nut just sit outside the forks then?
Offline Sniper X
  • Resistance is not futile, it is voltage devided by current.
« Reply #8 on: August 07, 2012, 10:38:18 AM »
Why would you want to do this? Looks? These old frames weren't designed for the larger width wheels stickier tyres and was was stiffer front forks. Sure it'll look odd and kinda cool but I predict the rest of the suspension and all the bushings will wear out faster and need to be replaced sooner. You might also have some very negative handling effects. or of course it might just work OK! I'd love to see pics and get a report when you do all this work.
1973 CB350 Four, 1969 CL350 Scrambler (2) 1985 BMW R80RT.
Offline xnewmanx
« Reply #9 on: August 07, 2012, 10:38:59 AM »
Yes. Or if you want to shorten the sliding spacer a bit you could tuck it into the fork cavity.
Offline wiskey
« Reply #10 on: August 07, 2012, 10:47:17 AM »
I'm doing it for the brakes. The improved suspension is a plus as well. Oh and well of course it looks killer.
Offline Sniper X
« Reply #11 on: August 07, 2012, 02:47:59 PM »
Then you can also get a wider rear rim and widen the swingarm.....
« Reply #12 on: August 07, 2012, 03:58:17 PM »
These "old" frames hold up quite well, go into the HIPO section and read the cycleX thread about their 750F race bike....
I have wider wheels on all 3 of my 750's, as long as you have some understanding of frame geometry and suspension, anything is possible... ;)
