Author Topic: Back to basics paint removal  (Read 2307 times)
Offline Sdsbassist
  • Gus, Austin, MN.
« on: August 09, 2012, 07:07:01 PM »
Gonna bring back the chrome fenders and muffler. Whats the best way to remove paint on chrome without jackin up the chrome?
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline fmctm1sw
Re: Back to basics paint removal
« Reply #1 on: August 09, 2012, 07:17:51 PM »
I'd recommend least lethal to most lethal.  Start with acetone or something and work your way up to a grinder :)
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #2 on: August 09, 2012, 07:23:35 PM »
Someone one time said oven cleaner?
Gus, Austin, MN.
Offline phil71
« Reply #3 on: August 09, 2012, 07:26:17 PM »
if paint stuck to chrome, then the chrome is probably mostly scuffed or rubbed off.. if the chrome was left alone, you should be able to scrape the paint off with a guitar pick.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #4 on: August 09, 2012, 07:31:31 PM »
Would a good alighty toxic paint thinner hurt chrome?
Gus, Austin, MN.
Offline phil71
« Reply #5 on: August 09, 2012, 07:36:17 PM »
no, that'd be fine. Did you paint the chrome? If someone else did it before you, they probably grinded the chrome off to make the paint stick.
Offline CycleRanger
  • No comment about being an
« Reply #6 on: August 09, 2012, 07:46:01 PM »
I have used Klean-Strip Strip-X on steel and aluminum. It's solvent based and should be safe for any metal.
I wouldn't use oven cleaner. Most contain sodium hydroxide.
« Reply #7 on: August 09, 2012, 07:49:36 PM »
No brainer here,throw some paint stripper on it,won't hurt the chrome,but if it was painted to begin with there is a reason,its probably Crap underneath. Nobody I know would spray bomb nice chrome,maybe you will get lucky or somebody had bobber fever.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #8 on: August 09, 2012, 08:00:32 PM »
PO was 28 bought when 17. Bobber fever....i scraped a bit of hidden fender and so far so good. If it is real bad, then it'll go gloss black anyway. Gonna try paint stripper tomorrow
Gus, Austin, MN.
« Reply #9 on: August 09, 2012, 08:18:38 PM »
Unlike wood that will bond paint,metal will not and is easy to check real qick with stripper if not a factory finish. Hope yo find some good stuff onder that coating  :)
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #10 on: August 09, 2012, 11:39:06 PM »
Tried Orange something or another stripper. Smelled ok (made wife happy? Tins underneath are a bit scratched but not rusty. Been painted at least twice with the blue and black.
Gus, Austin, MN.
