Author Topic: CB350-Running strange on left cylinder  (Read 2370 times)
dunnisher
« on: June 26, 2006, 01:31:51 PM »
last week my bike started to bog down and want to die during the first 1/8-1/4 turn of the throttle.. ive had similar problems which turned out to be gummed up carbs causing ristricted movement of the needle piston.
so i pulled the cards and gave them a good cleaning a few days ago.. problem still there!
so then i tried manually opening each carb to see if both sides of the engine were running the same..
the right side sounds and runs excellent.. but when i lift up on the left side throttle attachment, it sounds horrible. if i lift up very slowly it doesnt really studder, but doesnt sound good..  if i lift up fast itll really bog down and the engine will shut off..
i adjusted timing two weeks ago so i dont think that is the problem, although it could be if something migrated. i do not currently have a timing gun to check..
now to my suspicion...  me and a buddy rebuilt the top end two weeks ago which has lead to a pretty nasty oil leak.. it is leaking out from where the points attach to the engine.. he seems to think that the leak is due to a bad cam seal..
i dont know if a bad cam seal on the left side could lead to piss-poor performance on that side as well.. but it is the only thing i can think of..
does anybody have any ideas? ???  :-\
dunnisher
Re: CB350-Running strange on left cylinder
« Reply #1 on: June 26, 2006, 01:44:20 PM »
1970 cb350 with '69 cl350 engine which was recently rebuilt using the top end from the original '70 engine..
dunnisher
« Reply #2 on: June 27, 2006, 03:15:35 PM »
ANYBODY?????????????????
Offline Bill Vaughan
« Reply #3 on: June 27, 2006, 08:55:23 PM »
What do you mean by "sounds horrible"?  Since you rebuilt the top-end recently, I'd suspect the problem may be an extension of that procedure, but I'm curious what kind of sound you are hearing.
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline quietlikeachurch
  • You meet the nicest people...
« Reply #4 on: June 28, 2006, 02:13:05 AM »
Need to do a compression test on the left cylinder to determine if that is the problem, I just found my compression tester.  Otherwise, the spark plug might just be dirty.  Maybe oil leaking from the cam seal is getting on the points for cylinder #1?  Clean the gap with rubbing alcohol to check.  Are the carbs synchronized?  If it's not raining tomorrow (today?) give me a call and we shall investigate.
-Ian
'77 750F
snorklefork
« Reply #5 on: June 29, 2006, 08:34:16 AM »
did you reset the tiing and the points ?
