Author Topic: How to prevent polished bits oxidized almost instantly?  (Read 3982 times)
Offline davis96
« on: August 17, 2012, 06:42:45 PM »
I recently got done rebuilding my 71 cb500 (again) in my garage. Part of the rebuild was to paint the motor and polish the usual bits (see before picture)... However within a day of getting the bike outside, (there may have been a mist of rain, but it has definitely been quite humid) the parts that I spent so many hours polishing look like sh!t.
I am aware that moisture causes oxidation on bare aluminum parts, and that (according to my forum research) I would have to shine the parts back up "every now and then"... but this is nuts. Anyone else experience this? What kind of coating should I apply to abate this kind of oxidation? Wax? Clear coat? I don't need a miracle, just something that will let my polished bits shine nicely for maybe a month before i have to hit em with the alum polish..
The engine after polishing/paint:
Now all my polished parts look like this or worse:
'74 CB350F - sold
'71 CB500K
Re: How to prevent polished bits oxidized almost instantly?
« Reply #1 on: August 17, 2012, 06:50:19 PM »
Mother's mag polish works for me...
Online madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: August 17, 2012, 06:53:44 PM »
Followed by a coat of wax doesn't hurt either.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: August 17, 2012, 06:59:58 PM »
polished alloy is a labour of love.,over and over,thats why i dont bother with the fiddly bits.
Markcb750
« Reply #4 on: August 17, 2012, 07:05:29 PM »
I think what I see in the photos is residual pitting in the aluminum that reappears when the polish drys.  I found it was necessary to sand the surfaces to remove the pits, this involves removing several thousandths of an inch of metal.
I use a orbital sander to remove the majority of the pitting, then wet hand sand in 200 grit increments to 1500 grit paper.
then white or red polishing compound depending on which one seems to work best on the metal I am polishing.  depends on the alloy I guess, white most of the time.
Just an occasional touch up with mothers or one pf the other mag wheel compounds is all  seems to  take.
Offline Cheffish
« Reply #5 on: August 17, 2012, 07:07:58 PM »
Some mothers on a towel will clean that right up. It's from the rain
Offline fastbroshi
  • Puppet
« Reply #6 on: August 17, 2012, 10:01:46 PM »
+1 on the Mother's.  It'll keep the polished bits looking nice for a varying amount of time.  If you ride more, it's going to need touching up more often obviously.
Just call me Timmaaaaay!!!
Offline davis96
« Reply #7 on: August 17, 2012, 11:08:34 PM »
Thanks guys maybe I'll try mother's. I have no problem with labors of love or elbow grease, but I mean I haven't even ridden it once (unrelated engine issues). I guess I have to chalk it up to the super high humidity here, because even the polished stainless tach housing has not only oxidized, but is beginning to show signs of surface rust  :-\
'74 CB350F - sold
'71 CB500K
Offline Dave K
« Reply #8 on: August 18, 2012, 01:37:40 AM »
Aluminum is easy, try keeping magnesium pretty!
Offline trueblue
« Reply #9 on: August 18, 2012, 03:33:12 AM »
http://www.californiacustom.com/purple_metal_polish.html
I use California Gold, Purple metal polish.  It bends mother over and smacks its arse.  When I polished my bike, I started with 400 grit then 1200 then 2000 grit wet and dry.  Once I had lost almost all the skin off my fingers, I moved to a cotton buff with white wax, then cleaned with prepsol and applied the purple.  It brought it up like a mirror.  I give it a touch up when it starts looking a little dull, normally every 2-3 months, depending on how much rain we get.
1979 CB650Z
Offline RSchaefer
« Reply #10 on: August 18, 2012, 08:47:14 AM »
I polished all of my side covers and clear powder coated them.  I saw where another member on the forum had done this and I had purchased a powder coat system to do all the black parts so clear powder coated all of the polished side covers.
Valve Covers
Alternator Cover - I did the recessed HONDA in back powder.  Picture with powder before bake
and the gear #'s on the shifter cover
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Online madmtnmotors
« Reply #11 on: August 18, 2012, 08:58:30 AM »
Aw, man, now you've gone and made me want to do the same! The only issue I could think of would be the adhesion to the polished surface. I thought the powder had similar durability issues as clear paint when applied to polished surfaces in that it would peel from such a smooth surface. Has anyone had experience with durability?
« Last Edit: August 18, 2012, 09:21:41 AM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline RSchaefer
« Reply #12 on: August 18, 2012, 09:08:45 AM »
Well I have not got her all together yet so I am not sure, obviously hoping for the best.  Like I said there was another member who had done his with apparently god results.  I used the Eastwood Powder and the clear cures at 350 degrees and its the kind of powder that molecularity links and cannot be re-coated, so I am thinking I should be fine.
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #13 on: August 18, 2012, 04:16:08 PM »
California Gold is made by Mothers. ;)
My shifter cover was wet-sanded with 400, then 600 grit, then polished by hand with Mothers about a year ago. There is some road grime, but no oxidation. The horizontal line to the left of the shift shaft is a reflection of the kick-stand.
