Okay, I was typing on Ipad in garage. Here's what I meant to say:
I went out to the garage, put new fuses in and turned on the ignition. Then I pressed the rear brake. Then I pressed the rear and front brake together and blew the FUSE. I put another in and pulled both brakes and again blew the 15a fuse. Engine is not running.
I went inside and posted about display lights dimming when I pull front brake lever.
I. Go back out to garage and look for red and black WIRES that might short
I don't find any under seat, on frame or in headlight.
I. Do find a loose white male lead in headlight that sparks against a grind, so I cover it with shrink hose. (ACTUALLY, I WENT BACK AND ATTACHED THAT TO THE HEADLIGHT. NOW MY HEADLIGHT WORKS ON LOW BEAM).
I can't get the side cover under the shift lever off as all screws are seized and many are stripped.
Now that i have jiggled everything around, I can't get the fuse to blow anymore, NOR do the lights dim when I pull the brake lever. I found the leads from the f brake switch in the headlight and tried to make that work' but couldn't. The BLACK lead from that switch just sat in the headlight unconnected. The greenish lead with a yellow line connected to a like wire in the harness. I tried to short the green/yellow line to GROUND to get the light to work, but nothing happened
TOOTIRED:
I'll check to see if the fuse gets hot in a moment, when I take it for a test ride.
The fuses blow right in the middle, very obvious that they are severed.
As far as I know, the coils, headlights, etc. are stock. The bike has new turn signals.
I'll put a 20A fuse in and see. Is it reasonably safe for me to drive around the neighborhood with a 20A fuse in there?
MRONEGEAR:
Great. Thanks. I connected the black lead to a hot black lead and now the brake light works.
BOLLINGBALL:
I hear you and you're right. I've been wondering when someone on the board would get fed up with my questions. No disrespect taken.
I don't know what you mean by "do it right," however, when it comes to shorting the wires from the clutch perch. I don't have a clutch perch that allows for the switch to be attached. So, I followed the two leads from the clutch perch into the headlight bucket. and found the two leads that attach to the two leads going to the clutch perch. Then I connected the two leads in the headlight bucket and shrink tubed it. Now I can start the bike without pulling the clutch.
What would you advise me to do with the clutch wires differently?
