Author Topic: 1971 honda cb 750 project / Update problem changing oil  (Read 91754 times)
Offline Garystratos201
  • I have never been a
Re: 1971 honda cb 750 project / Video 3/19/2013 ITS ALIVE !!!
« Reply #250 on: March 20, 2013, 10:41:40 AM »
it was 78f degress here Sunday but its cooled off some. I think its about 59f degress here today...........Gary
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline iron_worker
« Reply #251 on: March 20, 2013, 11:02:07 AM »
That's open season for riding! Get out there! lol
IW
« Reply #252 on: March 20, 2013, 11:44:11 AM »
I`m probably at best a few weeks away from having her road ready. I`ve got another bass tournament this Saturday  which means I dont get to do anything to it until Monday. I`ve got to decide what to do with my tank. Its off what I believe to be a K5 and I eventually want to put a K1 tank back on it. I have nine cans of original Honda paint but I dont want to use it on the K5. I`m thinking of painting it a candy color and save the Honda paint until I  an find a good K1 tank that I can afford..........Gary
Offline Gregorymoto
  • SOHC Aficionado
« Reply #253 on: March 20, 2013, 04:50:48 PM »
Are you going to swap the head or keep it with the broken fins . I like that broken bits but clean bike look.
Yep, i have issues with this sort of stuff.
« Reply #254 on: March 20, 2013, 08:35:06 PM »
Dude where have you been ? Jeez, I dont know what to say...........Gary
« Reply #255 on: March 28, 2013, 12:49:33 PM »
Got my turn signals from member neilc and installed them and that`s when the fun started. The po had taken the winkers off at some point in time along with a lot of the related wiring in the birds nest that lives in the headlight case. After many hours researching the forum files and making new wires with plugs I succeded in getting them to lite up but not blink. I found a missing ground wire and replacing all four of the bulbs,  its a miracle......I`ve got winkers that winky wink !!!. Tires and tubes came in and are at the shop being installed on my old rims. I`ve ordered a new upper brake line from Z1, also all new banjo bolts and crush washers from Service Honda. Wont be much longer before I might get in a test ride............Gary
Offline cheftuskey121
  • Super Newbie
Re: 1971 honda cb 750 project / Update 3/28/2013 Winkers that winky wink
« Reply #256 on: March 28, 2013, 03:29:18 PM »
awesome Gary! I bet getting close is a good feeling. I havent updated in awhile but I have bee slowly working. going to do a proper update tonight! take care
Offline edhaeuser
« Reply #257 on: April 01, 2013, 11:14:58 AM »
You are getting close!  Sigh...I have much further to go.
Ed
« Reply #258 on: April 01, 2013, 12:30:46 PM »
Although it may be rideable soon its a far cry from being finished.lol I am still gonna buy frt and rear NOS fender, rims with spokes, still have to do the body and paint work. But I`m gonna ride her first...............Gary
« Reply #259 on: April 09, 2013, 10:36:15 AM »
Sorry I havnt done an update in awhile but with my grandaughters playing softball and my bass tournaments progress has been a little slow. But finally I sat on the seat and slowly let the clutch out it it acutally worked . It moved and took me down the highway............But I have a slight problem. Engine skips when under load and eventually dies at idle. I`ve double checked the timing and its good. I think it may be the spark plug wires and caps. I`m going to ordered new coils caps, and points and condensers. Saturday I ordered a nos seat from Motogrid, The one I put the foam in just doesnt sit right. I think the foam is not as dense as it should be. I will need to find the latch part that goes on the frame. I got my air compressor that had been sitting for years and found out it was locked up. So before I can do the paint and body work I`ll either find a used compressor or rebuild mine.  Its getting close to the time to decide if I`m going back with a K1 tank and side covesr or paint the K5  that is on the bike already. Its in great shape and no rust inside and the side covers are perfect except for the paint. Ahhh decisions, decision, decisions..............Gary
Offline iron_worker
Sounds like maybe you have an electrical part that is failing under heat/load. A cheap check would be to try new condensors. I think if you had a bad plug cap it would create a miss that was more consistent but I'm not sure about that.
What is your idle set at?
IW
Trying to set it at 900 but wont hold it, just kind of lopes and dies.......Gary
Hey Gary - I like the idle set little higher, try 1400 and set it after fully warmed up.
Pretty sure I have a spare seat latch if you need one.  Would be interested in buying your seat once you get the new one, could use it for a future K6 project.
Have the Bass been biting?!
Well so much for my seat order. Motogrid called last night and said it had been discontinued. I wonder why they still have it listed in their catalog? Oh well the search will continue. Stevo thanks for the advice on the idle I`ll give it a try. Its supposed to climb into the 80`s today here in Covingto Ga and I`m getting anxious to ride. I`ll let you know after this two day tournament how the bass are biting..........Gary
Offline iron_worker
Ya 900 is pretty low. I found that a 1200RPM or so idle seemed more stable and smooth.
IW
Thanks IW.........Anyone got some pics of the proper K1 seat? A couple different view would be great. Thanks ............Gary
Offline Kevin D
  • SE Michigan
Gary, I saved these photos from a 2010 ebay auction. This super clean K1 went for $11500 IIRC.
« Last Edit: April 10, 2013, 01:41:38 PM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Kevin D
  • SE Michigan
A couple more pics:
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Thanks Kevin . Is that whats called a duck tail seat/..........Gary
Offline Kevin D
  • SE Michigan
Nope, the ducktail was on the K0.  The tail stuck up about an inch, to keep the passenger from falling off??
3,000,000 for this one (in yen at Yamiya)
$30500
http://www.yamiya750.com/bike/B068e.html
« Last Edit: April 12, 2013, 02:16:26 PM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
Thanks Kev that clears it up for me.........Gary
Thanks Stevo but `Im in this deep its gotta be beter that........Gary
Offline Magpie
Try these guys http://www.hondanuts.com/cb750.html  They say to call them as it's discontinued. I have purchased from them and got good parts and good service. Cheers, Cliff.
Offline iron_worker
I used CMSNL ... not cheap but very nice.
IW
