Author Topic: Vinegar test on spare tank  (Read 2132 times)
Offline Tews19
  • I am no
« on: August 19, 2012, 03:18:42 PM »
I know this has been done and I decided to document the before and first attempt. I will rinse it out with a pressure washer. Hopefully that removes the remainder but I am very pleased with the results. Also, I know many have stated it will flash rust if not coated but this is a spare tank. I will see how bad the flash rust is in the morning. As for now, I am pleased with the results. Now leaks. Unfortunately while soaking I bumped it and put a little dent in the tank. I did nothing but pour in the vinegar and rinse out with a water hose.
DISCLAIMER: please do not mind my enthusiasm... I film the first time and do not edit it. I should edit and sound less pleased with the results.
http://s1090.photobucket.com/albums/i373/Tews19/?action=view&current=023-4.mp4
http://s1090.photobucket.com/albums/i373/Tews19/?action=view&current=043.mp4
1970 Honda CB750 survivor.
Offline nccb
  • 1974 CB750 Four
Re: Vinegar test on spare tank
« Reply #1 on: August 19, 2012, 03:49:51 PM »
I did the same and rinsed with water hose but then I tried using a blow drier to dry out the inside, which did a pretty fair job.  There as still some water at the back seams.  I kept mine inside until I can clean it up and paint it but it didn't flash rust at all.
Offline rice rat74
« Reply #2 on: August 19, 2012, 04:03:47 PM »
After vinegar+water rinse, I used denatured alcohol twice to absorb the residual water, then lastly used a large box fan.
Offline Ace2cool
  • 1974 CB550K
« Reply #3 on: August 19, 2012, 07:14:57 PM »
Looking forward to the results of flash rust test. That worked surprisingly well.
« Reply #4 on: August 19, 2012, 08:11:11 PM »
Flash rust may not be as much of a problem as if you had used something harsher like acid...try blasting a ton of wd40 in there and shaking it around, then dump in a quart of two stroke oil and get everything coated, then drain it out.
Offline lucky
« Reply #5 on: August 19, 2012, 08:30:34 PM »
Artists use vinegar mixed with water to make steel sculptures rust.
Offline Tews19
  • I am no
« Reply #6 on: August 19, 2012, 08:31:18 PM »
Ran down stairs after Lucky's post. No flash rust yet
Offline lrutt
« Reply #7 on: August 20, 2012, 04:58:19 AM »
Alcy will clean it out just dandy. I then hit mine with an air hose to dry out alcohol  then swished some 2 stroke oil in it just to preserve.
This was on a majorely heavy rusted CT90 tank. I used that Esprit rust remover BTW, worked well once all the big chunks were removed.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #8 on: August 20, 2012, 07:51:34 AM »
Use Heet to get the rest of the water out.
Offline lucky
« Reply #9 on: August 20, 2012, 08:06:02 AM »
Artists mix the white vinegar with 50% water. It starts rusting as it is drying.
Offline lucky
« Reply #10 on: August 20, 2012, 08:06:55 AM »
WD40 has silicone in it. Sure you want that in the tank?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #11 on: August 20, 2012, 08:37:27 AM »
Not according to the folks who make it;
http://www.wd40.com/faqs/
