Author Topic: 76 cb550k2 ballbearing home  (Read 1318 times)
Offline evo42
« on: August 20, 2012, 06:17:26 PM »
Hi - I have a siezed 76 cb550k2, posted my intro last night on the forum.  I drained the oil today and removed the right side case cover.  I removed the clutch pak and a small ball bearing fell out.  I've been searching the forum and have found references to this but not quite sure where it came from.  I believe it goes in the hole of the clutch spring mount (?) then the rod goes in after it?
I've attached the pic of what i'm referring to.
Also, see the washer on the right, that fell out too.  Can't find where this goes, wondering if it was on the kick start lever?  I've been looking at the schematics and manuals found on this site.
Excited as the motor doesn't seem to be siezed after I removed the clutch pak and reassembled the discs and plates.  Any help is appreciated...
Offline goldarrow
  • one day, i'll be an
Re: 76 cb550k2 ballbearing home
« Reply #1 on: August 20, 2012, 06:56:30 PM »
i have a 75 550 and when i went through my clutch, i don't ever recall seeing that single piece ball bearing.  the small rod with the ball end goes in to the hole to push the plate.
have a read of my thread here http://forums.sohc4.net/index.php?topic=105085.0
if your clutch checks out, nothing stuck there, your engine is probably stuck.  i just went through that few months ago.
and here's the link to my build thread
http://forums.sohc4.net/index.php?topic=106490.0
hope this helps, and that your engine is not as bad as mine.
have fun and enjoy your journey
CB550 K0
Offline evo42
« Reply #2 on: August 20, 2012, 07:04:56 PM »
Thanks for the reply, I've read your thread and am following the steps.  I'm hopefull I can get mine going too...
I'm referring to the bearing in these posts.  If these don't apply to my k2 bike then cool.  Previous to opening the case the kick start would not go all the way down.  Now the kick goes all the way down so I'm hoping it was the clutch pak that was frozen.  Bike sat for 7 years prior to running.
http://forums.sohc4.net/index.php?topic=87640.0
http://forums.sohc4.net/index.php?topic=91618.0
Offline luap
  • LAWL
« Reply #3 on: August 20, 2012, 07:13:11 PM »
+1 on small single ball bearing not being in the case. did you take the kicker off? theres a ball that rides inside of there acts as a stopper. Or did you take your triple trees off lots of balls that look like that inside. Quick google search will show where the lifter rod goes
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
Offline evo42
« Reply #4 on: August 20, 2012, 07:16:22 PM »
I did take the kicker off so sounds like that it.  I did do some searching on that as I thought the washer was from there too but didn't see a ballbearing reference.  I'll look again.  Thanks everyone for the help...
Offline evo42
« Reply #5 on: August 20, 2012, 08:24:50 PM »
Ah!  Found it's home inside the kicker housing that connects to the shaft on the bike.  I see the kicker lever has a cooresponding indentation for the bearing, I'll need to figure out how it goes when I reinstall.  Need to order the gasket first so now just degreasing until parts arrive.
Offline luap
  • LAWL
« Reply #6 on: August 20, 2012, 08:32:13 PM »
cool man glad you figured it out. id do the springs for the clutch while your at it. vesrah makes a good complete gasket kit for these bikes,
www.cb-town.com
Offline evo42
« Reply #7 on: August 20, 2012, 09:02:35 PM »
Sweet, thanks for the tip.  I'll add springs to the list...
 ;D So far so good...
