Author Topic: Removing new rear wheel bearings and re-installing in new hub  (Read 1088 times)
Offline CapeCafe
« on: August 21, 2012, 12:58:12 PM »
I wanted to see if anyone has had to remove a new set of wheel bearings right after installing them.  I installed a new set of All Balls Rear Wheel bearings into the rear hub of my 76 550K.  I used the heat the hub/ freeze the bearings technique to drop them in.  When I went to re-install the bearing retainer I cross threaded the retainer on the hub and wrecked half the threads.  I'm in the process of locating another hub and would like to be able to re-use the new bearings I just installed.  If I heat up the wrecked hub and push out the new bearings, do you think the heating process is going to wreck the new bearings.  I used 300 degrees for 30 minutes and the old bearings dropped right out.
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
1995 Ducati 900 SS/SP
2000 Ducati 900i.e.
Offline CoachDoc
  • 1974 CB550, 2005 GL1800, 1997 Valkyrie Standard
Re: Removing new rear wheel bearings and re-installing in new hub
« Reply #1 on: August 21, 2012, 02:41:30 PM »
I'd be more worried that the banging out process will produce damage.Might be a good idea to start fresh.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #2 on: August 21, 2012, 03:03:21 PM »
Well, I did. Put a new set in my rear and had to pull one out to fix a mistake. You "tap" them in - so you "tap" them out. Once vs twice - I didn't see any huge risk. But - doubtless - the ideal and best solution is NEW parts again. I used the old bearing as a drift to install and remove the new bearings.
Mark
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #3 on: August 21, 2012, 04:19:07 PM »
Use whatever tool you have to tap against the outer race.  Don't bang on the center or the inner race or you will likely do damage.
Offline CapeCafe
« Reply #4 on: August 21, 2012, 06:31:36 PM »
Thanks. I spoke with a guy at All Balls and he said the same thing.  Not to worry about the heat, worry about messing the bearing when tapping it out.  I figure I'll give it a try and if I get it out undamaged I'll use them again.
1976 CB550 K
2003 Kawasaki ZX12r
1995 Ducati 916 SPS
2000 Ducati 900i.e.
