Author Topic: 1976 CB550K Simplified Wiring Harness Questions  (Read 5085 times)
Offline 72BlackonBlack
« on: August 22, 2012, 12:52:27 PM »
Hey guys, I am trying to rebuild my wiring harness and going for the more simplified "bare-bones" idea. No turn lights, horn, gauges, switches, etc... I have attached a modified wiring diagram and I wanted to run it by the community to see what needs to be changed or altered. When I bought the bike, the switches had already been removed so the wiring was already modified. I am basically trying to start from scratch.
Keep in mind:
- I know the headlight doesn't have power going to it in the diagram. I have a fused line going directly to the battery with a switch.
- I do not have any handlebar switches
- This has a solid state regulator/rectifier
- It is kick-only
I am a relative newb to electrical, and am far more familiar with American car wiring, so I know I am kinda stepping in a little above my head on this one. If things need to be changed, no need to crucify me, just let me know and I can/will change it.
1976 CB550 Cafe (in progress)
1990 Yamaha Radian YX600 Fighter
1972 Ford Torino 472 BBF...
Offline LesterPiglet
  • 1977 CB550F2
Re: 1976 CB550K Simplified Wiring Harness Questions
« Reply #1 on: August 22, 2012, 01:07:35 PM »
Why don't you remove the SSM as well? It's pretty useless now.
Offline Goldbug
« Reply #2 on: August 22, 2012, 01:07:47 PM »
http://forums.sohc4.net/index.php?topic=97334.0
That is basically as simple as you can get, yours would be even more simple due to the solid state rectifier-regulator and kickstart only.
If you're not worried about your bike getting stolen you can replace the keyed ignition switch with a toggle switch with always hot "red" going in and switched "black" coming out. You can get dead simple with these things but a scratch-built harness is probably going to be inferior to an OEM unless you're using OEM quality/style connectors and the wire. Between Dime City Cycles and oregonmotorcycleparts.com/you can build an OEM quality harness but it won't be as cheap as the Radio Shack / Autozone way.
« Reply #3 on: August 22, 2012, 01:19:45 PM »
True... Without that will I still be able to kick start it in gear with the clutch pulled in?
« Reply #4 on: August 22, 2012, 01:23:27 PM »
That is the diagram that I was looking for I just couldn't find it... I guess it would be the same considering the same basic components are used, but would it be the same setup on a 550?
Offline Goldbug
« Reply #5 on: August 22, 2012, 01:29:36 PM »
It would be the same.
« Reply #6 on: August 22, 2012, 01:47:50 PM »
Anything would be better than the stock harness that is currently on the bike. The wiring shorted at some point and bubbled and melted the wire casings, plus wires are very brittle and connectors are terrible.
  • 1977 CB550F2
« Reply #7 on: August 22, 2012, 01:51:57 PM »
As far as I remember you just connect the two wires that would normally feed that diode.
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #8 on: August 22, 2012, 11:40:27 PM »
This the diagram for sohc4s from hondachopper.com its a easy harness to do. Its what i run and it has been real nice and its easy to add things to. This time im adding a indicator light for ignition on and one for bright headlight. And maybe going to add a 12v power outlet for a phone charger on the road.
« Last Edit: August 22, 2012, 11:43:08 PM by Gurp »
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #9 on: August 23, 2012, 02:26:06 AM »
I don't think you'll ever be able to kick start it in gear with the clutch pulled in whatever you do electrically.  ;)
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Round Dice
« Reply #10 on: August 23, 2012, 03:11:11 PM »
I did what you're looking for and got rid of the ssm, starter mag switch, clutch op switch, neutral indicator, and the oil pressure indicator after getting a side mount needle gauge.  Oh ya, the emergency switch went away too.
New to forums, not motorcycles.
