Author Topic: Cb450 tune up question  (Read 3537 times)
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« on: August 23, 2012, 07:35:20 PM »
Went to set the lash between the cam and the cam followers but the right exhaust side will not even adjust remotely close. Following the book The other followers adjusted out great. I see movement on the troubled follower but just doesn't seem to have enough adjustment range.
Assume this action is on some type of cam to pivot like this? Do you think the cam lobe is worn out to cause this? Or do you think something could be out of alignment? How hard is it to replace a follower or adjustment pin?
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline bluesmoke69
Re: Cb450 tune up question
« Reply #1 on: August 23, 2012, 08:36:37 PM »
Do you have the shop manual? You need to follow instructions to get cylinder to TDC which is covered in manual. You can down load it for free. If you can not find it here I think do the ton has it.
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: August 24, 2012, 12:10:49 AM »
Are you saying that with the feeler gauge between the cam and rocker you cannot get the clearance down to specs?...Larry
Offline y2kc0wb0y
  • B00msh0cka
« Reply #3 on: August 24, 2012, 09:18:16 AM »
Yes; I'm following the book.
That's correct the follower will not adjust tight enough to get the desired spec..or even close. Looking at the adjustment range, the follower just rises and falls as you spin the adjustment pin. Feels like the cam lob it rise on maybe worn. Does anyone have a picture of the follower?
« Last Edit: August 24, 2012, 09:21:58 AM by y2kc0wb0y »
Offline MoMo
« Reply #4 on: August 24, 2012, 09:33:48 AM »
This link will give you the exploded view  http://www.mrcycles.com/fiche_section_detail.asp?section=2034373&category=Motorcycles&make=HONDA&year=1974&fveh=123266   .  It does seem as though the cam is worn.  I have done hundres of 450s in the past and never seen that problem.  You can pull the cam cover on the side where the problem is to get a better view...Larry
Offline y2kc0wb0y
  • B00msh0cka
« Reply #5 on: August 24, 2012, 10:45:22 AM »
Looking at the exploded and some eBay links it appears the Cam Follower Shaft # 7 here is what normally causes the follower to rise up and down. That is very interesting that it would have wear......I'm going build some heat in the engine as this bike is sitting for awhile, if its not any better after that, I'll tear into it.
Offline y2kc0wb0y
  • B00msh0cka
« Reply #6 on: August 24, 2012, 11:47:26 AM »
Looks like I might be able to replace that shaft with the engine in the bike. If I hold the cam follower with some needle nose pliers, remove the speedo housing cover and slide the shaft out the side, replace and reassemble. I don't see anything on the shaft I would loose other than needing to guide the shaft back into the follower.
Thoughts?
Offline MoMo
« Reply #7 on: August 24, 2012, 07:54:22 PM »
Thoughts?
You should be able to do that...Larry
