New bike that I couldn't get dialed in so pulled out the idle jet to see if it was clogged (it was) - and yes I know these jets are pressed in so you really shouldn't pull them out.
Well, someone had been there before. The end had numerous additional holes drilled to the point I'm not sure there's any metal left and all bent to sh#t, the center bore hole wasn't centered (or even close) and I thought the jet had been repaired as there was solder about midway up the length but after thinking about it maybe that was for an interference fit - maybe.
So this jet is in awful shape and I don't want to put it back in. I don't want to leave the other ones in as they are likely just as crappy.
Looking around I don't see any replacement jets (#35 stock size) available which kind of makes sense since you shouldn't take them out anyway.
Other than finding all new carb bodies, do I have any options or am I screwed?
Thanks for any help.
