Author Topic: recommended grease to use  (Read 2081 times)
eldar
« on: June 27, 2006, 08:50:55 PM »
Well I had things greased while back, a while.................back! Anyways it is time to do it again, this time I am going to do it.
I am looking to find out what types of grease are recommended where. Such as the axles steering bearings, the front brake pivot places like those,. rear swing arm and such. I dont care about brands just types.
eldar
Re: recommended grease to use
« Reply #1 on: June 28, 2006, 07:49:14 AM »
So no one greases?
Offline hcritz
« Reply #2 on: June 28, 2006, 08:46:34 AM »
Damn...I'm afraid it would start a Dino VS Syn. war!!!
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #3 on: June 28, 2006, 08:53:23 AM »
goose grease...
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
Offline crazypj
  • I'm brill, me
« Reply #4 on: June 28, 2006, 09:09:08 AM »
I used to use Castrol MS3, Moly grease, then Silkolene Race (ProRG2), couple of the synthetics I tried had to be used with a grease gun,worked well on swing arm pivots but did'nt seem to have right consistency straight from tube on head bearings and such I've also used FINISH LINE Grip Shift grese bicycle grease to lube throttle tube/handlebar.
For front and rear axles use any waterproof wheelbearing grease, assembly lube or anti sieze. dont use anti-seize on brake pivots, I'm using teflon grease there at present as its got a 400deg melting point
Now I've posted some reccomendations people can start dissagreeing with me ;D
PJ
eldar
« Reply #5 on: June 30, 2006, 06:59:16 AM »
Thanks pj.
Well I got some standard multi-use grease and some wheel bearing grease. Going to use the bearing grease in the swing arm probably unless someone says different, I think it may be too heavy and since the swing arm does not have long range of movement, maybe regular grease is good enough?
Offline Roach Carver
« Reply #6 on: June 30, 2006, 07:03:18 AM »
what about crisco?  ;D
eldar
« Reply #7 on: June 30, 2006, 07:45:26 AM »
Well I would rather smell like gas when I got off my bike!
