Author Topic: Problem solved?  (Read 2087 times)
Offline Magilla
  • My bike: 1976 CB750F
Problem solved?
« on: August 25, 2012, 02:45:16 PM »
Back in the spring I bought a stock 76 K6 CB750. It has always run rich.  I've cleaned the carbs and reset them but it still ran rich.   The jets said 105 and 40. But I could never lean it out.  Today I gave up and brought it to a mechanic.  He just called me to let me know that the jets were drilled out.  They were drilled to 110 and 48. Sheesh no wonder it ran rich.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline lucky
Re: Problem solved?
« Reply #1 on: August 25, 2012, 04:29:25 PM »
Now there is a good mechanic!! He actually measured parts and looked at the details.
BTW...ANYONE that drills out a jet should remove the numbers from the drilled jet!
Also if you have a electric engraver finish the job and put on the drill size.
This just cost Magilla frustration time and money.
« Last Edit: August 25, 2012, 04:32:03 PM by lucky »
Offline Magilla
Re: Problem solved?
« Reply #2 on: August 25, 2012, 06:33:09 PM »
It cost me a summer of riding too.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Dimitri13
  • 1974 CB550K
Re: Problem solved?
« Reply #3 on: August 25, 2012, 07:25:43 PM »
Hot damn! That is one good mechanic. Since we're on the subject, how is one able to measure the jet size? I never really understood what the numbers meant.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: Problem solved?
« Reply #4 on: August 25, 2012, 08:06:40 PM »
Back in the days when I worked on a dyno, it was a matter of go/no go with a set of drill bits. Increments of diameter increase varied depending on what set of drills you bought. Here's an example of a set on ebay.
http://www.ebay.com/itm/JET-DRILL-SET-WEBER-CARBURETORS-DELLORTO-WITH-PIN-VISE-/280932387076?pt=Motors_Car_Truck_Parts_Accessories&hash=item4168e00904&vxp=mtr
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Re: Problem solved?
« Reply #5 on: August 25, 2012, 08:30:35 PM »
yeah its not unusual to find a 265 hemi with six different jets if its been dyno tuned properly with webers.
Offline Magilla
Re: Problem solved?
« Reply #6 on: August 26, 2012, 06:53:54 AM »
The go, no go test with drill bits is exactly how this mechanic found the problem.  This guy only works on 69-78 CB750s and 550s.  Nothing else.  I'm guessing if your that specialized it helps you to figure out most problems even before you open things up.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline Magilla
Re: Problem solved?
« Reply #7 on: August 26, 2012, 02:09:48 PM »
As it turns out the mechanic that fixed my problem is a member of this forum.  So I would like to give him the well deserved credit.  His login on this forum is workingguitar.
If your in the Mass/RI area and need a mechanic, you should look him up.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline lucky
Re: Problem solved?
« Reply #8 on: August 26, 2012, 02:40:12 PM »
The jet sizes on Keihins are in mm's So a 110 main jet is 1.10 milli meters.
Multiply 1.10 X 25.4=.043 thousandths.
Offline lucky
Re: Problem solved?
« Reply #9 on: August 26, 2012, 02:43:04 PM »
Good job workingguitar!
Re: Problem solved?
« Reply #10 on: August 26, 2012, 06:25:26 PM »
I think you need a new calculator, Lucky. According to mine, 1.10 X 25.4 = 27.94. ;)
To convert from mm to inch, multiply the mm size by .03937.
Offline lucky
Re: Problem solved?
« Reply #11 on: August 26, 2012, 08:55:24 PM »
I actually just type in inches=mm into Google and it does the conversion for me and since my math is bad I count on them to give me the right answer.
Yes 25.4 =1mm (.03937 )
I should have stated it better.
Re: Problem solved?
« Reply #12 on: August 26, 2012, 09:01:56 PM »
Wrong again. 25.4mm = 1 inch.
Offline lucky
Re: Problem solved?
« Reply #13 on: August 26, 2012, 09:06:13 PM »
Yes you are correct.
Offline lucky
Re: Problem solved?
« Reply #14 on: August 26, 2012, 09:13:12 PM »
I should have said devide not multiply. The size of the hole is .043 thousandths.
I gave the correct size, I just did not state the equation properly.
I will be more careful in the future.
I just use the automatic calculator to make sure I get the right answer.
Now I have apologized twice.
Offline Magilla
Re: Problem solved?
« Reply #15 on: August 27, 2012, 08:21:18 AM »
Anyway you do the math it still comes out to to much gas
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline HondanutRider
Re: Problem solved?
« Reply #16 on: August 27, 2012, 08:53:13 AM »
Let's go for THREE!  :D
If as you say: "The jet sizes on Keihins are in mm's" - wouldn't that mean a 110 main jet was 110 mm in size? ???  You went on to say: "So a 110 main jet is 1.10 milli meters.? ??? ??? ???
