Author Topic: Electrical problems........oh joy  (Read 1351 times)
Offline Magilla
  • My bike: 1976 CB750F
« on: August 28, 2012, 03:48:18 AM »
Head light does not come on all of the time.
Neutral light is on all the time.  It gets brighter when in neutral.
High beam indicator light does not come on
Taillight blows fuses.
Could this all be from the same bad ground?  Do I have a positive arcing out on the frame?  Is it both of these and more?
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1988   Harley Sportster 883
1983   HD FXR Shovelhead
2003   HD Heritage Softail
2006   Victory Vegas Jackpot
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1970   Norton Commando
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
bollingball
Re: Electrical problems........oh joy
« Reply #1 on: August 28, 2012, 04:59:12 AM »
You sure don't say much about what you have tried so far. Has this all just happened? Was the bike running when it happened? Do you have a meter and know how to use it?
Maybe cause the head light does not come on
Might could help if I had a print. But there are so many to choose from ;D
Ken
Offline nccb
  • 1974 CB750 Four
« Reply #2 on: August 28, 2012, 05:21:06 AM »
I had a similar problem with my headlight and I couldn't track down any loose wiring.  I took the fuse harness off and gave it a good cleaning with QD electrical cleaner as it was pretty cunked up and it worked.  Try unplugging one thing at a time and cleaning it to see if that helps.
Offline MoMo
  • Ride like you're invisible
« Reply #3 on: August 28, 2012, 05:22:53 AM »
What model and year?  ...Larry
Offline Magilla
« Reply #4 on: August 28, 2012, 06:09:09 AM »
Bike:  76 CB750K
Ive owned it since the spring but I have only ridden it about 100 miles so far.  It is a project bike so I am still tinkeiring with it.
Fuse box was pulled and fully cleaned.
highbeam indicator does not come on even when the headlight it on (w/high beam).
cuircut seems good from the headlight to the first harness clip under the tank.  Wires from the fuse box back to the taillight are good.
Wires inside the headlight bucket are all clean and connected.
1972   Honda CB350
1972   Yamaha 500
1982   Yamaha 650
1980   Honda CB650
1976   Honda CB750K
1982   Honda CB750
1964   Honda CA95
1982   Kawasaki 550
1974   Honda CL360
1975   Suzuki GT550
1981   Honda CB750
1981   Honda CB750
1972   Yamaha U7E
1970   BMW R50/5
1976   Honda CB750F
Offline MoMo
« Reply #5 on: August 28, 2012, 06:25:08 AM »
Indicator is a separate bulb, you'll need to remove the gauge to check it. Wire is blue.
Neutral light is most likely dirt at the switch or a pinched wire. It is a light green and red wire.
Tail light is possibly a pinched or frayed wire under the seat.  Wire is brown.
Good luck....Larry
