Author Topic: 78 750 Starter Motor Interior Oil Seal  (Read 871 times)
Offline peckcj
« on: August 29, 2012, 05:33:49 PM »
There is a 24mm oil seal that is in the inside front cover of the starter motor where the starter shaft exits.  It appears to keep any excess oil from entering the electrical components of the motor itself.  Mine was damaged while rebuilding the starter, but I can not find any replacement part numbers.
The seal is a metal shell type (like the oil seal in the oil pump).  Does anybody know of the replacement P/N before I pick up an old starter on ebay?
« Last Edit: August 29, 2012, 05:49:12 PM by peckcj »
Offline CycleRanger
  • No comment about being an
Offline peckcj
Re: 78 750 Starter Motor Interior Oil Seal
« Reply #2 on: August 29, 2012, 09:46:52 PM »
Something like this?
http://www.ebay.com/itm/Oil-Seal-10mm-x-24mm-x-7mm-I-D-x-O-D-x-Width-mm-/320659035334
Kind of, but the shaft diameter is 13.4mm, so I dont think it would fit.  Also, the OEM seal is 6mm thick.
Offline CycleRanger
« Reply #3 on: August 29, 2012, 09:54:32 PM »
Try searching google for a metric oil seal 13mm x 24mm x 6mm and see what you get.
If you know the size someone will have one. :)
