Author Topic: Lightened 500/550 Crank & Superods  (Read 15446 times)
Offline kayaker43
Re: Lightened 500/550 Crank & Superods
« Reply #50 on: September 14, 2012, 07:14:43 pm »
I wonder if someone can plasma spray, plate or weld up and grind those journals?
Its a shame,.. I have a Yosh ported head that dropped a valve. maybe we can make a three cylinder 375 out of our scrap parts :o
Hopefully the rod bearings look better?
« Reply #51 on: September 15, 2012, 05:56:27 am »
Chambers can be fixed. You'd be amazed.
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #52 on: September 15, 2012, 06:38:35 am »
Getting two magneto covers, one is magnesium.
Offline kayaker43
« Reply #53 on: September 15, 2012, 07:36:14 am »
Never thought about fixing the chamber! I'm glad I saved it. The problem is that a stock 650 head most likely flows better than the ported 550 head anyway?
Offline Tintop
« Reply #54 on: September 15, 2012, 06:36:30 pm »
Greggo I wouldn't give up on the crank.  They can be built back up and hard chromed / micro polished.  Check out Hot Rod shops that do cranks, there's lot in CA.  The problem will be bearings, as Honda only had a limited selection, and some are no longer available.  You'd probably have to source replacement bearings 1st, then have the crank repaired to suit.  Won't be cheap though.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline Greggo
  • Somebody's
« Reply #55 on: September 16, 2012, 07:44:53 am »
I haven't given up just yet.  I'll take it up to my dad's shop partner, who will ultimately help me build this motor, and see if he thinks it's worth the work/$$ to save the crank.
I've been trying desperately to figure out what I'll need to make the magneto system work, but I've barely found anything. :-[
Has anyone here used a Yoshimura magneto?
« Last Edit: September 16, 2012, 07:47:03 am by Greggo »
Offline cbr954
« Reply #56 on: September 16, 2012, 07:44:59 pm »
I had APE fix a rod journal on my cbr900 crank...dont know why they couldn't fix yours unless they are all shot then price may be the factor.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline Greggo
  • Somebody's
« Reply #57 on: September 17, 2012, 05:49:59 am »
Yes, I have to speak with them, and maybe Jay is still watching this thread, but I think having to do all five may be expensive.  However, if it could be done, I would do it eventually (after saving some $$).  The cool factor with this crank is off the charts (to me at least).  The seller was a regular in the SoCal racing scene, and apparently has a private museum down there...very possible it's a real Yoshi crank considering all the other Yoshi parts he listed off as having used back in the day.
Offline Greggo
  • Somebody's
« Reply #58 on: September 17, 2012, 06:10:18 am »
Back to the magneto for a minute...I went looking for similar magneto set ups, and eventually found pics of the CB450/500 system.  The rotor pictured is for a CB450, and has the six poles, just like rotor on the lightened crank.  Am I on the right track here??  Could I pick up the stator from one of these bikes?  I could really use some guidance here.
« Reply #59 on: September 17, 2012, 07:01:27 am »
 CB 350 2win is similar, if you reasearch how they work, your answers should pop up..
Offline Greggo
  • Somebody's
« Reply #60 on: September 17, 2012, 07:42:14 am »
Thanks Frank.  Good to know I'm on the right track.
« Reply #61 on: September 17, 2012, 08:02:32 am »
 I think on a 350 you can run batteryless, but may have to add a capacitor or battery eliminator..(they are small)
Offline Greggo
  • Somebody's
« Reply #62 on: September 17, 2012, 11:53:33 am »
Well, I can stop looking/researching the magneto...he found the parts I need!!
Offline Greggo
  • Somebody's
« Reply #63 on: September 17, 2012, 12:44:07 pm »
Must be my lucky day!!  He found the tag for the '2' cam!
Offline Tintop
« Reply #64 on: September 17, 2012, 05:09:29 pm »
Christmas has come early!! 8) 8) 8)
77 CB550 Cafe build
« Reply #65 on: September 17, 2012, 05:42:40 pm »
That's awesome, quite a little haul.
Offline Greggo
  • Somebody's
« Reply #66 on: September 17, 2012, 05:49:45 pm »
Early Christmas, oh yeah!!  Drained my bank account, too!
Offline Greggo
  • Somebody's
« Reply #67 on: September 19, 2012, 01:53:54 pm »
I seriously doubt that they were balancing those cranks when they modified them back then. If you take the rods off, send it down and I will check it out for you.
Hi Jay,
Would you folks be able to source bolts to use on these CB500/550 Yoshimura rods?
Thanks!!
Offline Big Jay
    • CBRzone
« Reply #68 on: September 19, 2012, 02:04:55 pm »
I would have to see what they were. Also, we can fix the crank journals, but if it is more than one, it would be cheaper to find another crank.
You can send us the crank and a rod so I can check out the bolt. We will inspect the crank and let you know what we come up with.
http://www.racecranks.com/
Jay
Offline Greggo
  • Somebody's
« Reply #69 on: September 19, 2012, 07:26:44 pm »
Thank You Jay.  I am having them checked Friday by my dad's shop partner, and I will likely take the rods off as well.
I looked at your crank page.  Would the lightening/balancing quoted there bring it to this level, or somewhere between this crank and stock?
« Reply #70 on: September 19, 2012, 08:10:56 pm »
Nice score Greggo!
« Reply #71 on: September 19, 2012, 09:30:43 pm »
Just a question for knowledge sake...are the fasteners used on cranks for high speed/stress applications like this stronger than aircraft fasteners that are often metric 10.8 grade fasteners?
Do the fasteners have special properties that make them highly unique /specialized?
Offline Big Jay
    • CBRzone
« Reply #72 on: September 20, 2012, 08:43:22 am »
Yes on the modern bikes with Carrillos. The rod bolts are WAY stronger than 10.8.
Offline Greggo
  • Somebody's
« Reply #73 on: September 20, 2012, 09:33:26 am »
Nice score Greggo!
Thanks Stev-o!  The quantity isn't there like the Motherlode, but for about the same price...the quality is sure there!  Just found a price list that has the CB500 Complete Magneto Assembly listed at...$613  :o :o 8) 8)
Offline Greggo
  • Somebody's
« Reply #74 on: September 21, 2012, 04:54:39 pm »
Separated the rods from the crank today, and the five journals are DEFINITELY shot.  We're looking into having them welded up, just to see how much it costs.  The rods will be stress checked at the same time.  Also removed the magneto rotor from the crank before it was sent out.
