Author Topic: CB750 electronic ignition  (Read 9415 times)
Offline jrfixit1
« on: August 31, 2012, 05:37:44 AM »
What CB750 electronic ignition unit is rated the best? and works well with the stock coils? Thanks.
Offline aperry
« Reply #1 on: August 31, 2012, 05:56:33 AM »
No single answer.  Search Dyna, Pamco and Handaman ignition.  Ton of threads on this.
CB750K3 with F1 frame/swingarm
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: August 31, 2012, 05:57:36 AM »
HondaMan's Ignition Amplifier has the OldSchool_IsCool "Excellence in Member Made Components" award. Can't get a much higher rating than that in my garage!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Re: CB750 electronic ignition
« Reply #3 on: August 31, 2012, 06:05:48 AM »
have a google of the boyer bransden units,ive used few,you can email them and get solid answers back promptly,like how to hook up an electronic tacho for instance to one of their units.
« Reply #4 on: August 31, 2012, 06:28:18 AM »
I'd say they are all good (the ones mentioned above) I have a couple Dynas, probably will buy Hondamans next time.
Offline jrfixit1
« Reply #5 on: August 31, 2012, 06:51:13 AM »
Thanks Guys.
I have my K0 (engine 750E1002874) in hundreds of pieces, after 20 years of sitting in my garage. I drove it in the 80s until 92 as a cafe with S&W shocks, Kerker 4 into 1 and a 750F gas tank. I have all of the original parts, except gas tank and paintable headlight ears. Will be starting with a freshly painted frame.  Engine will be rebuilt soon. It was seized with a broken exhaust valve, but luckily the cylinders and pistons are unscored.
Regards, Joe
Online scottly
« Reply #6 on: August 31, 2012, 05:34:20 PM »
That is a very early '69 serial number. AKA the much coveted sandcast.  :o It may be a replacement case with the original number stamped on, BTW. I think the clutch cover has one less screw than the common die-cast.
Offline phil71
« Reply #7 on: August 31, 2012, 06:09:34 PM »
i like hondaman's setup, because you have a failsafe , should something go wrong. read about it.also, new on the scene>
http://www.charlies-place.com/PAGES/Store/electronic_ignitions_new.html
i put one on a 450 twin and it was a miracle. pricey tho.
Offline chewbacca5000
  • I polish covers!
« Reply #8 on: August 31, 2012, 06:48:17 PM »
You also get nice fine grain control with the option of setting 1,4 and 2,3 independently.
Offline unclebunt
« Reply #9 on: February 25, 2014, 01:42:37 PM »
wheres the best place to get a boyer bransden
Black 750K8
« Reply #10 on: February 25, 2014, 02:12:46 PM »
+10 I don't know of any other system that has this. Just does not make sense to me to To get a system that does not offer this.
« Last Edit: February 25, 2014, 04:59:11 PM by Black 750K8 »
« Reply #11 on: February 25, 2014, 02:16:32 PM »
I run Pamco and I am very happy with it. Pete has also excellent support service.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #12 on: February 25, 2014, 02:22:39 PM »
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #13 on: February 25, 2014, 02:48:44 PM »
The Dynas had a problem they knew about and never admit to or support, so I will neer buy another.
Pamco is easy to install and I have had no issues 2 years out in really hi temp situations and Pete is very good about support.
If the HondaMan was avauilable at the time I probably would have gone with that. If the Hondaman unit fails on the road, you can defualt back to the points. Mark would also stand behind his product.
