Author Topic: 1975 CB550K Ignition Switch location  (Read 3109 times)
Offline hereforever23
« on: September 03, 2012, 10:04:21 AM »
Hi- I'm a new owner. I just bought a 1975 CB 550 K-
the previous owner had mounted the horn where I believe the original ignition switch would have been located and the switch bolted to a bracket attached to the handlebar clamp just below the indicator lights.  The ignition switch from these models should go below the tank, no?  I've tried looking at the parts fiche but for the earlier 550's its really hard to read- they have so many parts listed on each page of the fiche.  I was hoping someone with an early 550 could take a picture of how the ignition switch is mounted so I can see which pieces I am missing.   It looks like there should be some kind of right angle bracket down there.
Thanks! great forum
Re: 1975 CB550K Ignition Switch location
« Reply #1 on: September 03, 2012, 01:12:01 PM »
For anyone looking...
I found it in the parts manual
its #55 in the "wire harness" section
« Reply #2 on: September 03, 2012, 02:08:33 PM »
Hi and welcome. On my '76 550 K, yes the ignition switch was originally mounted under the tank on the left side.
Offline DJ_AX
« Reply #3 on: September 03, 2012, 03:07:42 PM »
« Reply #4 on: September 03, 2012, 06:52:00 PM »
Wow you guys rock, thanks.
The bracket I think I need is part # 50375-323-020
unfortunately its discontinued and I haven't been able to track one down.  I'll keep looking...lemme know if anyone wants to sell theirs
Thanks!!
Offline luap
  • LAWL
« Reply #5 on: September 03, 2012, 10:01:38 PM »
I might have a bracket lemme look around tomorrow
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
« Reply #6 on: September 03, 2012, 10:26:19 PM »
Same as 500 four
« Reply #7 on: September 04, 2012, 12:18:25 AM »
The bracket I believe is welded to the frame and it isn't a flat piece of steel but it is a raised radiused part that  the ignition switch nose which is threaded around the lock cylinder protrudes through and a chromed special "nut that is round with slots cut into it secures the switch to the bracket. That is the design on my '74 cb550.
Same kind of concept as on very old cars with metal dashes that the ignition switch "bolted" to the metal dash panel with a hole in the dash. The securing trim ring or nut was a bit special so it looked good and it defeated normal tools for removing it.
« Reply #8 on: September 04, 2012, 06:00:50 AM »
It is not welded
« Reply #9 on: September 04, 2012, 08:00:34 AM »
I have a feeling that whatever the bracket bolts to may have been cut off since my bike came with engine bars. On my frame there is a single hole for a bolt perpendicular to the direction the key switch would face.  Is the bracket a right angle piece?  I'll try to take a picture of what I have
Offline DJ_AX
« Reply #10 on: September 04, 2012, 09:06:52 AM »
« Reply #11 on: September 04, 2012, 04:49:08 PM »
Mine was not welded
Mines welded on
Correction. My '76 K was not welded and has been moved.
« Reply #12 on: September 04, 2012, 05:17:06 PM »
Here is a pic of the key switch mount on a 75 CB550 K.
I bolts to the frame with a single 10mm bolt behind the forward frame down tube.  (Not seen in the pic.)
Offline GrandRapids750K3
« Reply #13 on: September 04, 2012, 05:18:40 PM »
That was a hard bracket for me to find... My PO had the ignition completely removed and turned into a switch under the seat. Found a couple of brackets but they sold so fast. It just has a bolt that tightens it around the tube. Good luck with your hunt, it was half the fun for me!
« Reply #14 on: September 04, 2012, 05:19:40 PM »
Should have looked closer... Mine is a 750... Good luck anyways!
