The SOHC/4 World Tour is in under way.
The rule of thumb is 0.004" end gap per inch of bore. 0.010-0.012" should be good.
Make sure the head is nice and flat and use a MLS head gasket, best gaskets around...
It comes with a head gasket when you order the piston kit. You may have to email the seller of the kits on ebay.
Bumpity.Has anyone had any pearls of wisdom to report about these 550 kits lately? I may doing it myself if I can find some current positive feedback.
Has anyone had any clearance issues (with valves) with the Cruzin image 601cc kit?
Hi all,Sorry to bring this topic back up. My cylinders are being bored as we speak, for this kit.What is the clearance I should use between piston & cilinder ? In MM if possible ( I'm from Europe)Thanks guys,Brgds,Elias
