Laid the wheel, sprocket side down over two 6 x 6" wood blocks
When I did this, I pulled the doughnut wheel out of a junk car, 15" wheels. It made this work a lot easier.
Those cushmans say pretty dark and greasy. I can't imagine they could deteriate much. When you clean the goop off, you might find they are better than new. The best cleaner for that wheel is oven cleaner, lye, from the dollar store.
Then again, I'm always buying things I don't need.
