Author Topic: Header gauge?  (Read 1142 times)
Offline Gonzowerke
  • I burn asses like a Bhut Jolokia, 'cause I'm a real
  • Member #106, Owner of the ORIGINAL Frankenbike!
Header gauge?
« on: September 04, 2012, 08:37:50 pm »
Once again, I searched first to no avail...What would be a good gauge of steel to use for a header/resonator build? I am making only one set, so I won't be buying the $800+ slip roller that can handle 16 gauge, but the cheaper ones only do 20. Is this too thin?
Opinions please!
Gonzo
1977 F2 "Highway Star"
1977 F2 "Bike-In-A-Box"
1978 K8 "Frankenbike"
1991 CRX Si "Buzz Bomb"
2000 Jeep Wrangler "UBoat"
2011 BMW S1000RR "TIE Fighter"
Offline BLUE71TURBO
Re: Header gauge?
« Reply #1 on: September 04, 2012, 09:24:42 pm »
 I wouldn't use anything under 18 gauge .043 in.   ;)
Offline Sprocketwerx
  • I'm just a motorhead, can't leave nuthin alone!
  • I like 'em fast and clean
Re: Header gauge?
« Reply #2 on: September 05, 2012, 08:22:29 am »
I've rolled 16ga with my cheap 3 in 1 roller, brake, shear.
It's rated @ 18 ga mild steel.
You just need to be patient and work slowly.
I assume you need the roller just for the resonator, and build the header itself using mandrel bends.
16ga mild steel or 18ga stainless would be my choice of materials, resonator could be 18ga MS depending how short the pipes are before the collector, i.e. "how hot does the resonator get?".
Dan "Sprocket" Harris
Sprocketwerx Motorsports
