Author Topic: RE: Propane Oven for powdercoat  (Read 10985 times)
Offline chewbacca5000
  • I polish covers!
« on: September 07, 2012, 01:25:25 PM »
I want to use this propane stove for powder coating small parts http://syracuse.craigslist.org/app/3250271456.html
  I don't see the problem with it as there is no way for the powder to come into contact with the flame.  I can roll it out on the lawn, hook up a propane tank, bake my stuff and roll it back.  I have no 220 in my garage.
Mega huge cooking ovens must be powered by gas anyway.  Check these guys out http://www.sprayboothsupplies.com/gas-powder-coating-oven-curing-12FT-high-12FT-wide-30FT-deep.html
Does this sound like something that will work?
« Last Edit: September 07, 2012, 03:17:20 PM by chewbacca5000 »
  • I polish covers!
Re: RE: Propane Stove for powdercoat
« Reply #1 on: September 07, 2012, 01:50:03 PM »
Offline nccb
  • 1974 CB750 Four
Re: RE: Propane Oven for powdercoat
« Reply #2 on: September 08, 2012, 06:00:34 AM »
I dont know anything about powder coating but how much heat is involved and for what time period?  If its 500 or above, I would be worried about that little oven for a long period of time.  I have heard of some ovens "melting" due to long bouts of high heat, since they are really only made for light residential use.
Offline trueblue
« Reply #3 on: September 08, 2012, 06:07:22 AM »
It should work, if I remember correctly with PC it needs to run at about 200C for about 30 mins.  All the commercial ovens are gas powered, so don't stress over that.
1979 CB650Z
Offline cgswss
« Reply #4 on: September 08, 2012, 06:40:10 AM »
I use something just like it.  A stove out of a rv.  I normally use 350 for 20-30 min with eastwood powder.
FYI, I bead blast the parts first, then I "gas out" the parts by putting them in the oven for about 10 min.  I spray them with powder while they are still hot, then pop them back in the oven to cure.  Doing it this way, I have never had a part peel.  Before I did the "gas out" cooking before spraying, I had a couple trys fail.
  • I polish covers!
« Reply #5 on: September 08, 2012, 07:14:47 AM »
Thanks a Million  trueblue and cgswss!  This just made my day!  I searched and searched the forum and all I saw was propane is a powdercoat No No.
Cgswss  if you could snap a pic of your oven and how you have it setup it would be most helpful.
Here is another idea that I am kicking around an old school solid steel enclosed trailer.  100% metal on the inside.  To build an enclosure like this would run me well over $1000.
Why not insulate the outside and add a heating element.  When I am not using it I can roll in into the back yard.  Use my jeep drag it up the hill cook my parts roll it back down.
« Last Edit: September 08, 2012, 07:32:07 AM by chewbacca5000 »
bollingball
« Reply #6 on: September 08, 2012, 08:02:34 AM »
 We made a pig cooker from one of those. You may want to put a regulating fan from top to bottom for uniform heat. For the burner we used black pipe with holes drilled that was the tricky part. Start small and work your way up. Most any place that builds cookers can help with that and the regulator size. You might want a 100# tank we used two 20#. A lover at the top to adjust temp in case it gets to hot. Look at any big grill for ideas
Ken
Ken
  • I polish covers!
« Reply #7 on: September 08, 2012, 08:15:10 AM »
Ken
Ken
Awesome!  So this idea is not so far fetched after all?  Can you snap a pick of your pig cooker I'd love to see how you got it setup on the inside.  Did you bother with insulation, or is it unnecessary?
I don't understand about the black pipe?   You mean to tell me you can just make your own heating element by drilling holes in the black pipe?
bollingball
« Reply #8 on: September 08, 2012, 08:32:32 AM »
The pig cooker is in another state now. Yes the black pipe works great if you can find a place that builds cookers they can make one up for you. They will have the hole size and regulator worked out. Take the inside measurements to them or even better pull the trailer to them. They can do this stuff in there sleep and save you a lot of trial and error. We insulated on the inside for a cooker you run it all day so it saves gas. Try it without depends how tight the trailer is You can get gaskets for the doors from the cooker place or maybe home depot. Try google home made cookers for more ideas
Ken
  • I polish covers!
« Reply #9 on: September 08, 2012, 08:47:20 AM »
Ken
Thanks!  Much appreciated.
Offline faux fiddy
  • bike in a box
« Reply #10 on: September 08, 2012, 08:58:00 AM »
This thread got me to thinking.
I used a kiln to match tile one time.
I made several trips to the place that did the firing, and then had a chance to get my own kiln pretty cheap.
I think it would be perfect for powder coating.
Then I got to thinking about porcelain parts. hmmm.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
  • I polish covers!
« Reply #11 on: September 08, 2012, 09:47:06 AM »
That is a great idea!  I would be paying them another visit. You could even do high temp ceramic.  You'd be everyone new best friend!
For now I think I might get this little oven for 25 to 50 and go from there.
http://syracuse.craigslist.org/ppd/3163752351.html
Offline faux fiddy
  • bike in a box
« Reply #12 on: September 08, 2012, 10:14:21 AM »
[/quote]
I actually latched on to a kiln pretty cheap but have never got it up and working. The Kiln is pretty big, you could do any tank, but not a frame. Swingarm, probably fits.
I don't know about it but I think it gets up to 3,000 degrees. I imagine any ceramic shop would do your cooking, I think they charged about $45 when I had a whole kiln full. My test pieces only cost a few bucks a pop. I guess it takes 12 hours or more.
I'm not sure exactly how they do it. 'Cone 6' is what they I seem to remember they  describe, I guess there's little things that melt at different temps and when the sixth one melts your glaze is cooked. Different times and settings for different material.
thehouseofclay.com
« Last Edit: September 08, 2012, 10:17:06 AM by fiddy of industry »
  • I polish covers!
« Reply #13 on: September 08, 2012, 10:59:07 AM »
That is interesting.  By cone 6 my powder would be burnt to char.  You would need more like 350 to 400 for powder coat so you'd have to figure out a way to dial it down.  Not sure if you can control the heat or not.
Offline Bodi
« Reply #14 on: September 08, 2012, 05:44:43 PM »
Typically a small ceramic kiln uses a cone as power/gas shutoff. The heat is on until the cone softens at its rated temperature: it's placed in a little clamp deal held open by the cone, it closes when the cone softens. The cones are exactly long clay looking cones, there are a few sizes but about an inch long is typical for home kilns. The heating coils in an electric one are pretty powerful and the radiant heat would probably damage nearby powder coating before the temperature reached your target. All in all an oven made to get to thousands of degrees is not suitable to use at 400. Big production size kilns are usually gas heated, and use electronic thermocouple controls rather than mechanical cone shutoffs. Assuming the control will work at such a low temperature that might be workable.
Offline shinyribs
« Reply #15 on: September 08, 2012, 11:26:06 PM »
There was an auction years ago in my town. I was some sort of company that does commercial kitchen remodeling/maintenance.i.e. Burger King,McDonalds...We picked up on old Subway bread warmer for $50. Well insulated stainless steel cabinet. As bis as a standard household fridge.It will hold a Cb750 frame easy. Added a circulationg fan and 10kw of electric heat. Works good and was cheap. Just another option to consider.
The darn fool didn't know it couldn't be done...so he went ahead and did it anyway.
My Hackjob build- http://forums.sohc4.net/index.php?topic=106103.0
Offline ncstatecamp
« Reply #16 on: September 09, 2012, 03:19:19 AM »
a lot of modern residential ovens have a self clean function which basically kicks it up to 500+ for 5 hoursish so all you have to do is brush out the dust of what ever was in there
also everything ive powdercoated has been 400 for 20 minutes, turned out fantastic and it was pretty cheap #$%* too
  • I polish covers!
« Reply #17 on: September 09, 2012, 05:52:03 AM »
Thanks SB!  This is a good tip.  This one would need to go truck, but is 30 x 40 x 73.  I have heard of people gutting out standup freezers, but this seems like a nicer solution.
  • I polish covers!
« Reply #18 on: September 09, 2012, 05:28:38 PM »
In addition to what everyone else has said about propane here is a cool video that shows massive determination.  I would really like to know if there are other materials than metal that would work to build an oven.  Sheet metal is big $$$$.  A ready made container is looking good right now.
powder coating on a mexican budget pt. 2
Offline shinyribs
« Reply #19 on: September 09, 2012, 10:10:24 PM »
Thats thinking outside the box for sure!   For simplicity sake,your standard kitchen oven will work just fine. Whether its gas or electric wont matter. So long as your parts will fit in there. Old ovens should be pretty easy to come by cheap on your local craigslist.
  • I polish covers!
« Reply #20 on: September 10, 2012, 04:31:45 AM »
Yeah that is what I am going to do for now.  I really admire this guys determination though.
Check out the results for less than $300 bucks.  It would probably be 500 to 700 to pay someone to do this.
MOV00811
