Author Topic: Oil pressure sensor keeps failing...  (Read 4772 times)
Re: Oil pressure sensor keeps failing...
« Reply #25 on: September 11, 2012, 07:00:48 PM »
i took an oil pump body and cover to a bearing supply and we just sized one up,it turned out to be 46x2,i think we have more metric stuff on the shelves over here?
Offline onepieceatatime
« Reply #26 on: September 11, 2012, 07:23:50 PM »
46x2mm
Has anyone successfully replaced this gasket? If so, what size did you use if you couldn't find this exact one? I remember I tried replacing it on the last one and got an SAE roughly equivalent, but ended up cracking the cover because it was too thick.
I replaced one on my 650. it sounds like the same size. PM me your address and I'll send one out to you free (USPS).
I had to buy a pack of 50. Only charge to you will be to let me and the forum know if it fits your 550 also. If it does I'll post the part # and source for everyone.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline Steel CB650C
« Reply #27 on: September 11, 2012, 07:33:47 PM »
I would replace the pump install a new switch with teflon tape remove the oil pan clean the strainer change the oil and filter use only new parts then go for a ride.
Ride for fun.
Offline Dimitri13
  • 1974 CB550K
« Reply #28 on: September 11, 2012, 08:59:49 PM »
Dave: Probably. At all the hardware stores they had mainly SAE stuff, with the only metric stuff being small or popular sizes.
One: Really? Awesome! I'll send you a pm and let you know asap.
Steel: I replaced it a few months ago, and it was perfectly find up until a few days ago. I am doing all that other stuff though. Just waiting on o-rings.
« Reply #29 on: September 18, 2012, 03:59:35 AM »
Got the o-rings today. Was surprised that it was a "square" o-ring. Nice and thick though, sat in the groove well.
Went for an hour ride, absolutely no leak.
Thanks again :)
This o-ring worked on my 1980 CB650s, and seems to be good for CB550s also.
I got it from McMaster-Carr, Part number 4061T178.
It is a 1.737" ID, 1.943" OD 0.103" thick square o-ring.
"The square cross section on these rings retains a seal longer than standard O-rings, especially at higher temperatures and pressures. Interchangeable with AS568A O-rings size for size. Buna-N is for use in oil applications. Temperature range is -30° to +212° F. Durometer hardness is A70. Color is black."
http://www.mcmaster.com/#4061T178
1965 CA77
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
