Author Topic: CB400 Four battery  (Read 2609 times)
Offline Cundalini
  • Honda CB400 Four owner since 1986
CB400 Four battery
« on: September 11, 2012, 11:21:40 AM »
Just bought a new battery for my 400 four.I go to the shop man in shop fills up with acid.I say " How long do I need to charge battery for when I get home" Man replies " You don`t! maybe perhaps ten minutes just to top the battery up" I replies "Unusual normally when I buy a new battery I have to put it on  a slow charge for a few hours until its shows "ready" on the charge" Man says "No this battery comes with the cells precharged.It doesn`t need charging."  He goes off fills it with acid ,comes back " Just measured your battery it`s pushing out a 13.something (Amp?) charge". when I get home I immediately hook battery onto charger "Ready" light goes out as soon as battery connected.Remains out ,only a slight glimmer of illumination after ten minutes.I leave on for a bit longer.Nothing! Slightly better illumination of "ready " light when switching from trickle charge to fast charge! Advice please.Should i I carry on charging? Another 39 quid down the drain :(
« Last Edit: September 11, 2012, 11:23:26 AM by Cundalini »
Cundalini wants his hand back.
Offline LoVel
  • Yes, I remember your mother well. She was quite the
  • 1972 CB500 four
Re: CB400 Four battery
« Reply #1 on: September 11, 2012, 11:24:54 AM »
That is the first I ahve heard of a battery that comes precharged without the acid in it.  Last one I bought they put it on the charger for an hour befor ethey would let me have it.
Sounds amazing but I don't believe it.
I'm an individual,  just like everyone else.
Offline Cundalini
« Reply #2 on: September 11, 2012, 11:26:42 AM »
Thats what the man said PRE CHARGED CELLS! before the acid is put in .Should I keep charging then?
Offline fmctm1sw
« Reply #3 on: September 11, 2012, 11:36:57 AM »
All of the batteries I've bought lately have been charged like that.  Just dump the acid in.  I think if you read the instrucitons (if any came with it), it will direct you to put it on a charger though.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Cundalini
« Reply #4 on: September 11, 2012, 11:46:00 AM »
Just had another look at it! Re connected the charger. The "ready" light when illuminated is very dim when on a trickle charge.When switched to fast charge ready light becomes much brighter.
