Author Topic: Throttle Cables  (Read 1884 times)
Offline clintcd
Throttle Cables
« on: September 15, 2012, 01:31:12 AM »
Hi,
I  bought a pair of used throttle cables on EBay for a 1977 CB750a, they seem to be a bit too short. The manual shows them routed quite low at the front of the frame but the ones I purchased just run under the front tank mounts. Can anyone tell me the correct length for the 1977 throttle cables and where they might be available.
Thank you.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Throttle Cables
« Reply #1 on: September 15, 2012, 07:02:01 AM »
The parts fiche shows that all three years (76, 77, 78) used different part numbers for the cables.  Do you have a 77 bike?
« Last Edit: September 15, 2012, 07:07:27 AM by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline clintcd
Re: Throttle Cables
« Reply #2 on: September 15, 2012, 08:23:07 AM »
Hi kandrtech,
Yes my bike is a 1977 model, the cables I bought were advertised as being for this model but I suspect they are from a 1976 bike which I believe had lower bars.
Regards
Offline dave the welder
  • dave the welder
Re: Throttle Cables
« Reply #3 on: September 15, 2012, 06:52:32 PM »
pull cable       casing 41"   cable 46"     push casing 42.1/2"  cable  46"these are off my 77 and i think they are original
don't buy it build it
Offline clintcd
Re: Throttle Cables
« Reply #4 on: September 18, 2012, 07:38:45 AM »
Hi Dave The Welder
Many thanks for the information.
