Adjusted the valves on my 550 and then went to sync the carbs. Got them synced pretty close, and went to tighten the adjusters up. It was dark out, and I somehow knocked the carb linkage apart and it took some wiggling and forcing to get it back together. Then I tightened it all up and left it for the night.
Went for a ride this morning and it felt great. Knocks and ticks were gone, and it had great power. Rode for about 20 minutes, and it started to get a little sputtery, and then cylinder 1 was popping and backfiring. I figured maybe I'd better double check the carb sync, so I hooked it all back up. Trying to sync it, the idle was racing up to 4-5k. I manipulated the choke to get the idle down enough to work. The gauge needles were all in the ballpark, but I couldn't get a satisfactory sync.
Looking at the adjuster screws, I could see that at least 1 and 4 were backed out way further than they were originally, because of the line of grime on the screw. I screwed them back in a few turns, and checked the sync again. Was then able to get them all really close and called it a day.
So, this is basically just a long way of saying, could my carb adjustment have been so out of whack that the needle on the synch tool went all the way around the dial the wrong way, so that it looked like it was matching up but in fact it was way the #$%* off?
Haven't taken it for a ride again yet, had to run out. But it seemed to idle a lot better after I re-synched.
