SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
Proven Tricks & Tips / How To's - NOT for Quesions
Suspension
(Moderator:
Gordon
Topic:
Rear Suspension Disassembly
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Rear Suspension Disassembly (Read 4887 times)
thebearded1
Full Member
on:
September 18, 2012, 12:12:16 PM »
Here is a way I took my shocks apart when I didn't have an extra set of hands. Place the shock in the vise right side up. Run the tie straps through the spring then back through the ratchet. Ratchet them down equally as far as you can. Sometimes you may need to push the spring down a little more to get the shims out. I had to in my case since the covers prevented me from compressing more of the spring.
Logged
75 CB550K
edwardmorris
Youngish
Old Timer
Do not cause harm, nor respond to harm with harm.
Re: Rear Suspension Disassembly
Reply #1 on:
December 11, 2013, 07:39:31 PM »
Perhaps this will help somebody someday. Thread rod, old dicing board, a hole saw and a vice grip. Ignore the zip ties in the pix, bad idea that failed.
Logged
72 CB750 - Rebuilt to NEW OLD STOCK
BOTM August 2015
BOTY 2015
73 CB750 - Project Terry's Fault
Braided Stainless Steel Oil Lines CB750
Don't meet your heroes, stay clear of the Open Forums.
754
Really Old Timer ...
Reply #2 on:
December 11, 2013, 09:43:31 PM »
I used a holder for top of shock that goes in the drill press.. Now I built an even slicker setup that goes in the lathe.
If you have Harley buddies, or can find. At a swap meet, big twin clutch plates, and the reddi rod should do it easily..
Logged
Kelowna B.C. Canada
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Suspension
(Moderator:
Gordon
Topic:
