Author Topic: Dimensions gl1000  (Read 1162 times)
Offline dakota
Dimensions gl1000
« on: September 19, 2012, 07:08:42 AM »
Hi,
who knows the dimensions of the brake disks (front) of a gl1000 1976?
inner + outer diameter
thanx
gp
Offline CBGhia
Re: Dimensions gl1000
« Reply #1 on: September 19, 2012, 09:36:55 AM »
http://www.ngwclub.com/
Check over here.
Offline 78 k550
« Reply #2 on: September 19, 2012, 09:29:24 PM »
I have a set off a 77 in my front room.
I don't have a measuring tool here I can do it at work tomorrow.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Xnavylfr
« Reply #3 on: September 20, 2012, 01:23:33 PM »
As close as I can measure (rotors still on wheel) the OD =11" and ID=2.59+or-.
This will get you in the ballpark but for exact I'll have to take rotor off wheel!!!
Xnavylfr(CHUCK)
Offline 78 k550
« Reply #4 on: September 20, 2012, 04:43:16 PM »
10 7/8th" OD
2 1/4" ID
This them off the bike. with tape measure I can use another measuring device if you want exact.
I'm pretty sure they used the same hub as is on my 550 rims so I would think if the used the same hub the inner diameter would be the same.
Paul
« Last Edit: September 20, 2012, 04:45:50 PM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
