Author Topic: loss of powers after 3 fixes  (Read 1163 times)
Offline apostrophe28
« on: September 20, 2012, 12:29:20 PM »
cb750 k7
So I've been experiancing a loss of power after riding for a few min ( almost feels like I'm on 2 cyl ), so i did my searching and reading.
-battery is perfect
-plugs look alright
-replaced plug caps w ngk 5k ohm
-flushed tank and cleared any debris from petcock.
I'm sure my floats are off because the overflow tubes regularly leak gas...would this be the issue?
I'm seriously at a loss right now
1977 750k
Offline killersoundz
Re: loss of powers after 3 fixes
« Reply #1 on: September 20, 2012, 12:31:34 PM »
If the overflows leak it's likely the float valves are worn out. It shouldn't necessarily cause a loss of power though. Does the bike sound like it's only hitting on two cylinders? Mine will only run on 2 cylinders sometimes when it needs a points adjustment. The points wear out and need adjusted. that's where I'd look
My project thread:
http://forums.sohc4.net/index.php?topic=107447.0
My CB750K4 Starting up for the first time after a seized motor and rebuild!
« Reply #2 on: September 20, 2012, 12:48:51 PM »
off to the garage for a points adj and valves!...
...keep it coming w the ideas guys lol
1977 750k
« Reply #3 on: September 20, 2012, 01:02:48 PM »
Start the bike  and let it run for a few minutes or take it for a short ride.Shut it off and take a wet rag and touch the header pipes up by the engine on all 4 pipes and compare the hissing sound of the water and see if any of the pipes are running cooler than optimal. Get you closer to finding the trouble spots. The rag should hiss loudly if all is good,watch the skin.
Offline oldfart
    • The Motorcycle Project
« Reply #4 on: September 20, 2012, 01:53:29 PM »
The symptom sounds perfect for blocked bowl vent holes.  Early PD series carbs have silly 0.020" holes in the sides of the castings for bowl vents.  The ability to run for only a few minutes, coupled with the continuous overflow, points right to this being the problem.
Mike Nixon
Why is there never enough time to do it right, but always enough time to do it over?
www.motorcycleproject.com
bollingball
« Reply #5 on: September 20, 2012, 02:21:31 PM »
How many miles sense your last complete 3K tune up?
Ken
Offline lucky
« Reply #6 on: September 20, 2012, 09:28:25 PM »
If the dwell cannot be brought into spec you will need new points and condensers.
