Author Topic: How do I peen a Tsubaki cam chain master link? (and anyone got pics?)  (Read 9295 times)
Offline ksteve
Bike: CB750K2
Task: Replace cam chain without splitting cases;
Parts: Tsubaki BF05M 94-link cam chain; Tsubaki BF05M master link;
Problem: Master link is hard-nosed; how to stake/rivet/peen it?
As many here have suggested, I plan to cut my cam chain, split the new Tsubaki, thread it in and re-link it with the Tsubaki link. I ordered several links from Z1:
http://www.z1enterprises.com/ItemDetails.aspx?itemDescription=Cam+Chain+Master+Link+Tsubaki+BF05M&item=TU25-9920.
The Z1 site shows a master link with soft/hollow link-pin tips. So I also ordered a Motion Pro chain tool built for hollow-tip pins.
What arrived in mail has hard-nosed links, not what the Z1 site shows. The Motion Pro tool won't work with these.
I called Z1 tech support; the tech guy said these masters are all hard-nosed, and that the pic on Z1 site is wrong. I asked how to stake these solid-nosed pins; he recommended I split the cases to attach the continuous chain instead of using a master.
I know some of you have put in these chains without splitting the cases and have had good results. Do you have advice and pics of how you staked these hard-nosed master links?
Thanks,
Steve
« Last Edit: September 21, 2012, 02:01:49 PM by ksteve »
Offline ksteve
Re: How do I peen a Tsubaki cam chain master link? (and anyone got pics?)
« Reply #1 on: September 21, 2012, 03:06:56 PM »
is this the effect I want to shoot for? (perhaps by knocking the corners with a hammer and drift, if a tool isn't available for our small chains)
or is this good enough?
(These pix are from an interesting site I stumbled on from automotive world:http://www.peachparts.com/shopforum/general-information/203367-timing-chain-crimper-how.html)
bollingball
« Reply #2 on: September 21, 2012, 03:21:04 PM »
I don't think there is a lot of force on the side plate They all look fine to me. I would do it myself. Let us see what the pros say.
Ken
Offline phil71
« Reply #3 on: September 21, 2012, 03:48:58 PM »
isn't there a tool for exactly this job?
why chance it.
http://www.powersportsplace.com/parts/ptm-pp2589?gclid=CP-zmeXgx7ICFUje4AodMVAAng
Offline ksteve
« Reply #4 on: September 21, 2012, 04:11:10 PM »
why chance it.
Have you used this? The site doesn't give much info. It isn't clear whether it can crimp/peen solid pins. I already have one (MotionPro) that can do hollow pins.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #5 on: September 21, 2012, 04:14:40 PM »
I would go with the second pic. It's only to stop the pins sliding sideways. Just make sure you don't press them too far so as to add a stiff link in the chain.
Offline fmctm1sw
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline ksteve
« Reply #7 on: September 21, 2012, 07:53:39 PM »
previous discussion on the matter:  http://forums.sohc4.net/index.php?topic=94956.msg1056941#msg1056941
Yeah, I saw that. But the z1 tech I talked with said it needed to be peened, but really wanted me to split cases. So Z1 is not talking with one voice, which leaves the question. If a press fit is official, I'd think Z1 tech guy would tell me that.
