Author Topic: gasket sets  (Read 512 times)
Offline 750fchop
gasket sets
« on: September 23, 2012, 12:37:59 AM »
 Aloha all;
 Anyone know what the difference is between gasket sets for early 750 SOHC's and later ones including F's ? I need top end gaskets for my F and some sellers specify early and late.
mahalo, Eric
Offline tony sawyer
Re: gasket sets
« Reply #1 on: September 23, 2012, 01:21:15 AM »
all the gasket sets i've brought recentley are pattern and cover all some have o rings on the studs think this idea was binned cycle x do a fancy set very nice very expensive regards tony
Offline Dimitri13
  • 1974 CB550K
Re: gasket sets
« Reply #2 on: September 23, 2012, 02:30:38 AM »
Eric, what island you on?
Offline 750fchop
Re: gasket sets
« Reply #3 on: September 23, 2012, 06:50:23 AM »
 Maui, you ever get over here?
I just updated my profile a little.
Eric
Re: gasket sets
« Reply #4 on: September 23, 2012, 09:04:26 AM »
I also think it's mainly the head gasket with the o-rings for the oil returns in the later engines. You may have to cross reference each gasket to see which one(s) have different part numbers. I had 2 different Honda kits (no longer available) for the bottom and they worked fine. If you wanted Honda gaskets you have to purchase separately anyway.
