Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Still looks like a #530 chain. Another way to tell is a stock 78 running a 630 chain has a rear sprocket with 41 teeth and most of the earlier bikes that run the 530 have a 48 tooth. There can be some variation if a person changed the gearing. You may see the tooth number stamped on the sprocket when cleaned or give them a count.
MCRider,What do you mean by the angle is bad for sure? SO considering that the chain matches the motor, but not the sprocket, should I look into getting a new sprocket. So far when riding I havent noticed anything with it. What do you think?
