well... seems the electrical starting system is pretty old, windings look really old as well, and i dont think the solenoid for it works... also, i found out this bike hasnt been started in over 12 years, after cleaning the carbs and putting new spark plug caps on, it started on just the third kick...
so with kickstarting that easy from a cold start (i dont think it can be much colder of a start of sitting 12+ years) ive found myself debating if i even need the electrical starting system or not?... ive been thinking of just omitting it when i redo the wiring for the bike and just run it on a kickstarter...
does anyone do this?.. the starting motor is a lot larger than i thought it would be too for a motorcycle.. havent weighed it though, but seems id shave a fair bit of weight off the bike too if i removed this, and went with a much smaller lithium battery to act as a power buffer between the electrical system and the alternator and shave another fair bit of weight when alls said and done
heres another question... the compartment where the starting motor sits, which has an access panel on top of the transmission, without the starting motor there would it be possible to use this area as storage without risking damage to the engine or damage to anything stored there?
so anyone do anything like that?.. keep in mind this is a cafe project, i dont plan on rebuilding it to factory original, i find kickstarting fun, and one of my goals is to lighten the bike up more if i can, without sacraficing on-road performance...
one other semi-related question i have is for those who have increase compression.. i was wondering what new compression ratio youre running now in the engine, and how much more difficult you find it to kickstart?.. because with modern fuel getting more and more ethanol added to it, it seems there would be an efficiency benefit from higher compression.. and i know more compression means tougher kickstarts.. so i was curious if anyone has any experience relating to it?
bike is a '76 CB550F
