Author Topic: my DIY CNC 3 axis milling machine...out of acrylic and scrap  (Read 30982 times)
Re: I am building a CNC 3 axis milling machine...out of acrylic
« Reply #50 on: November 23, 2012, 03:13:22 PM »
Try changing the screen resolution .... ;) That may distort the image but you should be able to find a setting that will fit the screen....
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #51 on: November 23, 2012, 06:40:59 PM »
I did somthing..? First I messed with the font size and that just screwed up everything. What I did was right click on the desktop...I just tried to do it again and now cant find the option that I used. There was a box that was checked off for "best results" that I unchecked, and was warned against, but worked great. I just have to move the cursor to an extreme edge and the screen jogs to the edge so I can see all of the information that is needed.
« Reply #52 on: November 27, 2012, 07:10:36 AM »
ITS ALIVE!!!! ALIVE!! [/size] (thanks brent for that motor tuning torque tip)
« Reply #53 on: November 27, 2012, 07:02:04 PM »
Pics or it's dead!
« Reply #54 on: November 27, 2012, 08:55:00 PM »
I made a crap video. One thing I never took into consideration was the...acoustics of the thing. All of the vibrations and tones of the motors sound like Dubstep. My problem now is learning the program to edit files muy rapido. I need to have this thing set-up and running Saturday night.
Steve O- the seat came a few months back. Nice. The color was a Duplicolor Burnt sunset or some BS. I have the can at work and will get back to you. maybe. if I feel like it.
« Reply #55 on: December 02, 2012, 06:38:45 PM »
TURN OFF SOUND. my camera sucks.
I had the mill up and running at an art opening for an "apocolypse" show. I had it drawing spines, skulls, flowers, and stars. People loved it, or at least told me they did. It only failed once..and I dont know why. It was just stuck on one line of code.
The bed is so unstable. I have added a 1/4" aluminum strip below the X axis and still has flex. bla
« Reply #56 on: December 03, 2012, 07:54:31 PM »
Preservation Framer Art Gallery in North Attleboro
This is a slidewhow video of the show. Now it is time to have the thing make stuff for me.
Re: my DIY CNC 3 axis milling machine...out of acrylic and scrap
« Reply #58 on: February 17, 2013, 01:55:09 PM »
Can't see the video Joe, says its private... ;)
« Reply #59 on: February 17, 2013, 02:15:34 PM »
That is a lot of tool hanging out, can you shorten it up ?
« Reply #60 on: February 17, 2013, 02:42:53 PM »
Yeah, it can go farther into the collet. The tool was only .01 and it was supposed to be just scratching the surface, but (oops) ended up going about .015 into surface. As you can see from the 1/4" aluminum that I have "C" clamped onto the back of the Z axis there is still some play. But, for all thats its worth....its good enough for what I am doing.
« Reply #61 on: November 02, 2013, 07:50:18 AM »
I am now converting it to mill (try to) cast aluminum.
« Reply #62 on: March 06, 2014, 06:29:59 PM »
Here is my current experiment. I am learning Arduino and how to use Processing.
https://www.youtube.com/watch?v=RbXMncm_nIM&feature=youtube_gdata_player
Offline cabrala
  • Super Duper
« Reply #63 on: March 13, 2014, 01:05:43 PM »
I took a course on Processing and have some Arduino gear. Don't make me go out there to that place you call home!
Seriously though, if you want to borrow the "Learning Processing" (orange) book, it is all yours.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Need a better, newer points cover gasket? How about rubber washers for the headlight bucket? Click the link below:
http://forums.sohc4.net/index.php?topic=122308.0
« Reply #64 on: March 13, 2014, 08:12:04 PM »
Is that the book "Milling for Dummies"?
Offline cabrala
  • Super Duper
« Reply #65 on: March 14, 2014, 05:34:08 AM »
I could probably use that book as well, but Learning Processing is about beginner computer scripting or code writing. The class I took was focused on generating computer graphics and simple video games. I had some other goals for some art installation work but that hasn't happened yet. Either way, this book just goes step-by-step through the generating of code so it helps for a newbie like Joe  ;D .
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
Offline LesterPiglet
  • 1977 CB550F2
« Reply #66 on: March 14, 2014, 07:04:30 AM »
How can I make the program window smaller on the screen. The button I need to press in order for the whole thing to work is off the screen...about at the "f1" key.
Ctrl and + to make the type larger and Ctrl - to reduce.
Ctrl and 0 goes back to normal size.
« Reply #67 on: March 14, 2014, 07:03:15 PM »
Hey there, if you have a book to offer, I will take it. I need some points gaskets as well.
I just cut and paste. Mixing others sketches for my own purpose. I messed with Ruby on Rails for a hot minute as well.
« Reply #68 on: March 16, 2014, 07:59:52 AM »
http://youtu.be/RbXMncm_nIM
<iframe width="420" height="315" src="//www.youtube.com/embed/RbXMncm_nIM" frameborder="0" allowfullscreen></iframe>
<object width="420" height="315"><param name="movie" value="//www.youtube.com/v/RbXMncm_nIM?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/RbXMncm_nIM?version=3&amp;hl=en_US" type="application/x-shockwave-flash" width="420" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
So that is 4....and no vid ? wtf?
« Last Edit: March 16, 2014, 08:06:14 AM by FrankenFrankenstuff »
« Reply #69 on: March 16, 2014, 09:54:07 AM »
Are you making wedding rings now?   I've lost at least three.....
« Reply #70 on: March 17, 2014, 03:56:13 AM »
Yeah. Aluminum. My last one was white gold. Wifeypoo won't notice. I made two, just in case.why isn't that video embedding?
Offline cabrala
  • Super Duper
« Reply #71 on: March 17, 2014, 07:46:09 AM »
Well then, let's meet up soon. I'll PM you to figure out how to make that happen.
-Alex
'75 CB750F
'77 CB550K
'78 CB550
'93 FZR600
« Reply #72 on: May 23, 2014, 08:12:01 PM »
Just got my new delta style 3d printer going....
https://www.youtube.com/watch?v=MbFOV7HUis8&feature=youtube_gdata_player
Tonight I solved the centering issue. Wasn't firmware....it was my lack of connecting motors and end stops in conjunction w/ each other.
The CNC is still a work in progress. I am thinking about switching the Y Cartesian slide with a round polar disc. A spinning xy. 8)
« Reply #73 on: August 18, 2014, 06:43:49 PM »
Here is a link to some other projects and ideas....of mine
Lavek-tek http://lavek-tek.blogspot.com/
« Reply #74 on: August 18, 2014, 07:00:01 PM »
Dude, how do you find time for all this??
