Author Topic: After cam swap, won't start | Block off pics  (Read 22452 times)
Offline Trav-i
  • Has finally become an
Re: After cam swap, won't start | Block off pics
« Reply #150 on: October 18, 2012, 09:52:45 AM »
Hopefully I can shed some light on what's going on.  I'm headed to see him and his bike in just a few minutes.  It's always hard to diaignose via pictures, video.  So far I don't see anything majorly wrong with this engine, but hopefully seeinng it first hand will help.
Travis
Forum member #9962
1992 GL1500 Interstate
Offline 750resurrection
« Reply #151 on: October 18, 2012, 10:00:45 AM »
 Safe and speedy travels.  ;D
Offline stereosilence
  • 1975 CB550K
« Reply #152 on: October 18, 2012, 03:06:37 PM »
I'm pretty sure the exhaust port and timing were things from previously that I already had cleaned. Trav-i and I got the valves out (mostly Trav-i). I dropped the sump and found my puck and cam sprocket chip (and some other stuff). I took the stator cover off and everything looked good.
At this point, I am going to plan to take everything apart, blast all the cases and put back together. I plan to hone the cylinders and lap the valves and probably replace the rings. So, I guess this thread will be dead and you can follow my build thread if you are interested. Hopefully, it will all go back together and work perfectly forever after and we'll never know what the noise was  ;D.
« Reply #153 on: October 18, 2012, 03:30:41 PM »
 OMG ! lol the torture level is exemplary.
 Wait a minute - "and some other stuff" sounds very promising, would you like to expand on that ?
 Noooooo Mr bill... noooooooooooo
« Last Edit: October 18, 2012, 03:32:34 PM by 750resurrection »
  • 1975 CB550K
« Reply #154 on: October 18, 2012, 04:07:12 PM »
Not much to expand on. I was dredging the sump and picked out a few bits and pieces. Who knows what all could have accumulated down there since last time the sump was taken off.
Offline millerza
  • Zach Miller
  • 750K8 fixing rebuild probs
« Reply #155 on: October 18, 2012, 09:37:33 PM »
so it doesnt make the noise anymore? or what?
Offline luap
  • LAWL
« Reply #156 on: October 18, 2012, 10:06:04 PM »
"and probably replace the rings" Id put that a little higher on the list then probably. Imo id def do the ring while your at it
75-550 ffsc sold, 78-550 diamonte sold, 125s grasshopper sold, 76-550 puma sold, 78-550 tracker sold, 74-550 verde diablo Sold, 74-550 Noemani finished trying to sell. 72 500 hartail in the works
www.cb-town.com
"I dont need a bike covered in paint an chrome I know exactally bout how big my coc( is"
  • 1975 CB550K
« Reply #157 on: October 19, 2012, 06:04:41 AM »
millerza: The top end is completely off. I am going to hone the cylinders, replace rings, dethrone the engine, blast, paint, and put everything back together. Only then will I know if it still squeaks and hopefully it won't. Either way, it will be a few months.
Yeah, I am going to do the rings. They are cheap. I'm a little miffed cause I bought a top end gasket set...and now I am planning to do the full thing. Is it possible to get the rest of the gaskets or should I just buy a full set and try to resell the top end set?
Offline LesterPiglet
  • 1977 CB550F2
« Reply #158 on: October 19, 2012, 06:10:26 AM »
Dethrone?
  • 1975 CB550K
« Reply #159 on: October 19, 2012, 08:04:32 AM »
Yes. It currently resides in its regal shrine: enthroned in the frame.  ;D
Offline luap
  • LAWL
« Reply #160 on: October 19, 2012, 08:14:17 AM »
Return the topend gaskets kit an get a complete vesrah kit- sirius con inc is a good spot to pick one up
www.cb-town.com
  • 1975 CB550K
« Reply #161 on: October 19, 2012, 08:33:19 AM »
I got mine through ebay, so I'm not sure I can. I'll see though.
Offline crazypj
  • I'm brill, me
« Reply #162 on: October 19, 2012, 09:01:49 AM »
I would say there is something going on at #3 cyl.
Piston top looks different in pics plus you can see where exhaust has been leaking.
 Removing alternator cover would be a simple smart move, easy to see if anything has been rubbing (it's been know to shift if bike falls over)
 Is there really a shiny area around valve seats?
