....right side footpeg/brake pedal/kickstart don't interchange between frames, so if you have a k frame, you must use the k r. footpeg, brake pedal, and kickstart lever...if you are running rearsets, it doesn't matter. The seat and tank frame mounts are identical between the f and k, but the f's tank is longer and the seat shorter than the k's, so if you use an f tank, you must use an f seat, if you use a k tank, you must use a k seat. Also the sidecover tabs on the left side are different, but there are different options you can use. F frame can use f specific sidecovers or 77-78 k sidecovers but the 74-76 k sidecover will not fit the tabs. 74-76 k frame must use 74-76 k sidecovers...I don't know about 77-78 k frames in regards to using f sidecovers. F bike also uses a slightly different swingarm...but it swaps into k frames. Just be sure and keep axel spacers and axel adjusters together with their associated swingarm...also k model 4 into 4 exhaust will not mount to the f passenger footpeg mount, the passenger footpeg mounts are different and '76 k gauge cluster is different from '76 f and later bikes...here are some comparison pics of the different axel adjusters, wheel spacers, and right side foot controls
