yep:
on the list..
engine....RTV was used by the PO, so teardown is needed, eventually.
new gaskets all around - valve cover gasket leak over #3 - stripped valve cover bolt needs helicoil.
dual front rotor setup/forks/trees. have rotor(s) cross drilled.
(cant figure out why my bars continually cant to the right. ive tried everything)
lossa/coneeng reverse cone muffler.
HID headlamp conversion
trim rear fender shorter, rotate up under seat, new(brighter) brake light.
vinegar tank treatment, new fuel tap.
motor starts well and runs like a champ, except for the slight valve cover oil leak and the RTV gasket material showing. i dare not pick it out as its probably holding me together, thanks ufcking PO, whoever you are
might make it another year before a total rebuld is needed.
we'll see what actually gets done...
