Author Topic: 73 Honda cb450  (Read 1836 times)
Offline bigragu
73 Honda cb450
« on: October 05, 2012, 05:15:04 PM »
Just picked up a cb450 it runs but the left side pipe does smoke? Could it need a valve adjustment? Not real familiar with this bike 1st one.
Markcb750
Re: 73 Honda cb450
« Reply #1 on: October 05, 2012, 05:27:11 PM »
Gray smoke...oil.  Try some Seafoam (or similar) over night in the cylinder bores.   Do not reinstall the spark plugs till you clean out the Seafoam by kicking it over a few times.
Black smoke..running rich, clean the Carbs, reset the floats and sync them.
Usually not valve adjustment.   Although not a bad idea to check when bringing the bike into good working order.
Offline bigragu
Re: 73 Honda cb450
« Reply #2 on: October 05, 2012, 06:10:22 PM »
Thanks for the info, it's white/gray smoke so maybe I'll give the Seafoam a shot and change the oil?
The oil did smell like gas not sure if that"s related or a separate issue?
Markcb750
Re: 73 Honda cb450
« Reply #3 on: October 05, 2012, 06:23:23 PM »
Always best to get unknown oil out and new oil in.  I would let the Seafoam work on the piston rings before you change the oil.
When  I did this Seafoam flush on my 750 over 10,000 miles ago  I put a few milliliters in each  cylinder every few days for about a week.
The 450 motor is pretty durable, My '67 sat outside from 1982 to 2011.  Motor still kicked over! I have it tore down now as part of a restore.
Offline JohnG
  • 1976 CB750F - original owner
Re: 73 Honda cb450
« Reply #4 on: October 06, 2012, 03:27:09 AM »
I'll toss in one cautionary note.  If you change the oil  and then go to start the bike, crank it over a bit  (maybe with the plugs out and a second battery)  so as to get oil to the top end before running.
The oil delivery system is a bit more primitive than the 750  (see shop manual for details)  and it can take a little bit of time for oil to get up there.  There is a centrifugal filter you can clean on the left side.  Also a strainer on the pump.
A real drawback is lack of an oil pressure light!  More reason to be conservative. You don't want to fry one of the cams and it's followers.
1971 CB450
1979 CB750F
1982 CB900F
1983 CB1123F - Rick Stetson motor
Offline bigragu
Re: 73 Honda cb450
« Reply #5 on: October 06, 2012, 04:12:52 PM »
worked on it today and tried the Seafoam with little results? There's a very slight trace of smoke coming out of the left spark plug area? Thinking I need to replace the head gasket?
