Author Topic: SS screw kit with phillips heads  (Read 1528 times)
Offline derelicte
  • '74 CB750
« on: October 06, 2012, 01:20:28 PM »
Anyone selling one?  I've only seen allen sets, definitely more functional but I don't want to depart from the stock look.  Phillips would've been fine if honda hadn't used lead (apparently).  Thanks
Offline Dimitri13
  • 1974 CB550K
Re: SS screw kit with phillips heads
« Reply #1 on: October 06, 2012, 02:24:52 PM »
Have you tried ebay? I believe I've seen replacement bolt kits (as opposed to allen kits). If not, get on McMaster Carr and order the bolts you need.
Offline reliv77
« Reply #2 on: October 06, 2012, 02:51:56 PM »
Am I thinking wrong to try a new set of Allen bolts and a re torque the Cylinder Head Cover for a slight Oil Leak?
Offline bjbuchanan
« Reply #3 on: October 07, 2012, 08:13:13 AM »
Its alright if you are retorqueing them not just getting ham fisted and trying to get it as tight as possible.
Offline brewsky
« Reply #4 on: October 07, 2012, 09:36:51 AM »
I've been tempted to try these, but haven't yet.
http://www.rimfire-eng.com/CB750_Ordering_Page.htm
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline derelicte
  • '74 CB750
« Reply #5 on: February 13, 2013, 02:54:43 PM »
Sorry to revive an old thread.  One more check to see if anyone knows of any other options?  The site posted is the only set I've seen (thanks for posting that brewsky) but wondering if I can beat the $55 for a stainless set.
« Reply #6 on: February 13, 2013, 06:17:06 PM »
Have you called Mid States? The screws are 6mm of various lengths, 30-55mm.
Mid-States Bolt & Screw Co
Serving the South Bend Area.
(800) 482-0867
Offline Redrider969
  • "What fun to be on the road again." B. Baggins
« Reply #7 on: February 13, 2013, 07:51:06 PM »
Go to www.boltdepot.com.  You have to know the diameter, lengths and number of each you need.  You can get the info from the parts manual.
« Last Edit: February 14, 2013, 11:30:31 AM by Redrider969 »
Redrider969
Offline brewsky
« Reply #8 on: February 13, 2013, 08:00:55 PM »
Rimfire also shows mild steel versions, which I believe are zinc plated, for less.
Actually they are supposed to be less corrosive than stainless when used in the engine case application.
Most bolt places can get the 6mm phillips heads, but the head diameters are 12 mm instead of the oem 10mm.
I found some at my local dealer in stock.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
